s4 na removing wheel hub
Old Sep 4, 2005 | 01:16 PM
powrdby13B's Avatar
i'll blow YOUR valve off
Got the wheel hub + brake assembly off... but i can't figure out how to get the CV joint to let loose. Can I just pull on it? (it's not broke... yet)
Old Sep 4, 2005 | 07:39 PM
eyecandy's Avatar
You may need some PB blaster/WD-40 you should be able press the half shaft in. If not you will need a gear puller/pusher to press the half shaft in. When you go to reinstall it, take a wire brush and clean the hub and halfshaft end, then place a nice amount of wheel bearing grease on it.
Snoopy FD
Dec 8, 2015 01:45 PM
TheAsset
Sep 5, 2015 04:36 PM
fidelity101
13
Aug 31, 2015 07:47 PM
