Power FC Idle Rpm
Old Sep 1, 2005 | 03:37 PM
Mfanto's Avatar
Fanno
Idle Rpm
I just got a single turbo installed, and now my rpms are dipping down at idle. Is there a way to raise the idle RPM a bit on my power FC? If so can ya break it down for me?
Thanks
Old Sep 1, 2005 | 04:07 PM
RotorJoe's Avatar
Hooray For Boobies!!!
http://www.scuderiaciriani.com/rx7/power_FC_manual.pdf
Read that.
But it will be under the settings tab, then the Rev/Idle tab, then you'll be changing the values in the last (lower) three settings. Those are for the idle with no load, idle with electrical load and idle with the A/C on.
Old Sep 1, 2005 | 05:36 PM
Mfanto's Avatar
Fanno
thanks man.. it seems like it does it till I drive it for a while.
Old Sep 1, 2005 | 05:44 PM
RotorJoe's Avatar
Did you disconnect the battery recently?
Becasue the PFC goes through a pretty indepth idle learn process every time you disconnect the battery. It needs to idle in all three stages (no load, electrical load, and A/C on) for ten minutes or so before it starts to come around and idle solid.
Read this also
http://www.apexi-usa.com/pdf/product...tation/197.pdf
Old Sep 1, 2005 | 07:11 PM
cewrx7r1's Avatar
Eye In The Sky
Help the PFC by MANUALLY adjusting the idle up a little. Don't ask how, search or read the Mazda manual where it tells how.
24seven_dada
20
Nov 10, 2018 12:03 PM
gxl90rx7
Haltech Forum
Jun 30, 2017 11:30 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
The1Sun
Sep 7, 2015 10:21 PM
