West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
need some one to help me
Old Aug 27, 2005 | 11:14 PM
Keegan's Avatar
I need somebody within surrounding states around Oregon that would be willing to drive to Oregon to help me make my RX7 run right, or I can drive to them. We are very, very limited as to money. Thank you, Keegan.
Old Aug 27, 2005 | 11:19 PM
tIIsleeper's Avatar
pp
Why dont you just post whats wrong with it.
Sideways7's Avatar
What kind of problems are you having? We can walk you through most any problem on the boards here. Also, try to search before posting stuff. Theres a ton of info on the boards already.
Old Aug 27, 2005 | 11:33 PM
Keegan's Avatar
no matter what i do i can not get the car t idle lower than 1500. and it makes this poping sound
Old Aug 27, 2005 | 11:48 PM
Sideways7's Avatar
What do you mean you cant get it to idle? Will it die if it gets below 1500? Will it idle steady but not go below 1500? If it dies below 1500, I bet that you have a vaccuum leak you could suck a cat through, to quote another member. Try turning the idle screw on the intake manifold to see if you can keep it from dying. Once you get it to stay on (even if someone else has to keep it from dying) and spray carb cleaner around to see if the idle evens out. Also, look around to see if theres anything obvious like a missing vac line or something unplugged. Be sure to look behind the engine, too.
Old Aug 27, 2005 | 11:49 PM
Sideways7's Avatar
Oh, what are the circumstances of this? Was it running and suddenly started messing up? Did you buy it like this? Was it gradual?
Old Aug 27, 2005 | 11:55 PM
Keegan's Avatar
if it idles below 1500 it dies there are no vaccuum leaks that i can find and it idles rough i bought it like this and one of the actuators was broken and bunch of fuses in the eng bay
Old Aug 28, 2005 | 12:09 AM
Sideways7's Avatar
Check the tps, it can cause idle issues also. Theres tons of threads around about checking it.
Also, what is done to the car?
Old Aug 28, 2005 | 12:17 AM
Keegan's Avatar
the car is stock just no cats
Old Aug 28, 2005 | 12:20 AM
FC3S_nataku's Avatar
mattg prob nt coming back
you should comp check it
