NE RX-7 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, OH, WV, MD and VA
Turbo Removal and Gasket Change
Old Aug 27, 2005 | 04:54 PM
California Dreaming's Avatar
The Captain
Question Turbo Removal and Gasket Change
Turns out I need to pull my turbos to change the exhaust manifold gaskets to cure a leak. This is a little beyold my expertise and I would be a little more comfortable if someone else would be willing to do it. I live in central NJ, East Brunswick to be exact. I have no problem dropping the car off. If someone has a weekend to do this for me it would be appreciated, just let me know what its going to run me. Thanks in advance.
Old Aug 28, 2005 | 06:35 AM
amp's Avatar
amp
old yella
suggest you pick up new studs and nuts as well...
howd you determine its an exhaust leak..
Old Aug 28, 2005 | 01:30 PM
The Captain
I knew I had a leak because of the dreadful sound the car was producing so I took it in to my mechanic to have them change my downpipe and install a midpipe with a high-flow cat. All I knew at the time is that there was a bad flange on the old downpipe but after changing the parts the sound still remained. My mechanic traced it back to the exhaust manifold and then noticed the warn gaskets.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
