Power FC Is my car ok to drive?
Old Aug 25, 2005 | 05:53 PM
willjs7's Avatar
3 and the hit for $100?
I have Intake, DP, MP, CB, and am running the base map, i just put on 1600cc secondaries and used the datalogit to enter them and the lag time, how will my car run, using the base map and the injectorys, will it run rich?
Old Aug 25, 2005 | 06:32 PM
mjw's Avatar
mjw
Your car will not run any richer than it did before, by changing the CC setting on your injectors the PFC will adjust the map to compensate. I'd be very careful with that many mods on a base map if I were you.
Old Aug 25, 2005 | 11:11 PM
twokrx7's Avatar
Need more sleep
Ignoring the fact that you should tune it for proper AFR's etc ... did you change the injector overlap and other settings like I suggested in the sticky for 1600's?
If not, you may get a lean stumble at injector transition.
Old Aug 26, 2005 | 06:25 AM
willjs7's Avatar
.24 is the setting for injector lag right?
Old Aug 29, 2005 | 07:31 AM
willjs7's Avatar
bump
immanuel__7
89
Sep 5, 2015 10:23 AM
fastrx7man
33
Sep 2, 2015 09:42 PM
Marty RE
Aug 13, 2015 11:19 AM
