Power FC My car seems to have a fuel cut on the dyno
Old Aug 23, 2005 | 09:50 PM
starchild1's Avatar
Newbie
Exclamation My car seems to have a fuel cut on the dyno
I Just bought a PFC an I need some expert help. I whent to the local dyno and ran the car to confirm my AFR's with the base map. I made 4 Pulls the revs would stop climbing at about 6100rpms in 4th. Could this be over boosting and hitting the PFC fuel cut? The HP curve is very rough not smooth. My mods are DP, MP,CB ,intake. I did not notice the fuel cut before going to the dyno. Has any one had this problem.?
Old Aug 23, 2005 | 11:35 PM
cewrx7r1's Avatar
Eye In The Sky
Compare the boost that you were running to what the manual says about FUEL CUT in the section covering boost control.
Old Sep 3, 2005 | 12:56 AM
snarp's Avatar
Newbie
Question
check speed sensor or to much boost for map sensor ?
Old Sep 3, 2005 | 09:37 AM
twokrx7's Avatar
Need more sleep
Sounds like ignition breakup to me. Fuel cut is very abrupt and therefore noticeable. If it just doesn't want to pull and the hp curve is ragged, I would think ignition is your problem. Of course, you may be too rich for the ignition but I would suspect plugs and plugwires first.
Monsterbox
Jul 29, 2022 10:48 PM
dkwasherexd
May 27, 2017 04:51 AM
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
Clacor
Aug 14, 2015 09:17 AM
