Microtech lt8s fc with 13bre
Old Aug 18, 2005 | 11:54 PM
mattgsc's Avatar
lt8s fc with 13bre
has anyone ever wired theres up for a 89 fc with a 13bre in it, if so how hard is it and did you have any problems, this is my frist time dealing with microtech i normally run a Power FC but wanted to try something different.
Old Aug 19, 2005 | 12:14 AM
RexRyder's Avatar
yea its pretty easy. Just re wire a couple plugs into the FC harness: TPS, CAS, thermosensor, water temp, etc. Also for the TPS wire: if you are getting weird tps readings, use the other wire, since the re TPS is 4 wire type, and FC 3 wire type. Yea I think thats how it is.
Old Aug 19, 2005 | 06:53 PM
mattgsc's Avatar
dont u just use the harness that comes with the microtech ?
Old Aug 20, 2005 | 02:00 AM
RexRyder's Avatar
yea thats pretty much what I meant. my t2 came prewired with t2 stuff.
Old Aug 22, 2005 | 12:48 AM
TonyTurboII's Avatar
Glock Lover
Im currently running this setup.
What turbo do you plan on using?
Old Aug 22, 2005 | 11:24 AM
mattgsc's Avatar
i plan on using a gt35r with a t4 hot side. i got a hks t4 manifold. so basicly all i have to do is wire up the clips and plug in and go? the motor is race ported pretty much built 3mm seals and all.
Old Aug 22, 2005 | 12:13 PM
Bukwild's Avatar
go with a bigger turbo. If you have a ported RE that can spool a larger snail easy
Old Aug 22, 2005 | 01:43 PM
RexRyder's Avatar
what would you recommend for a stock port 13b re?
Old Aug 22, 2005 | 02:04 PM
mattgsc's Avatar
what kinda ignition coils are you using? the bosh ?
rx2333
Dec 5, 2004 12:14 PM
AdrianE
Microtech
Mar 18, 2004 11:12 AM
silverrotor
Microtech
Nov 6, 2003 12:53 AM
$150FC
Haltech Forum
32
Sep 4, 2003 08:14 AM
jacobcartmill
14
Dec 30, 2002 06:32 PM
