Power FC apexi pressure sensor pim scale?
Old Aug 18, 2005 | 05:43 PM
lmt's Avatar
lmt
Newbie
Hi,
recently bought an apexi pressure sensor, the one found with the avc-r.
i was wondering if anyway has a tested pim scale and offset?
i have tried the one in the manual but the reading isn't right
Old Aug 18, 2005 | 08:17 PM
cewrx7r1's Avatar
Eye In The Sky
Try any of these or combinations while you calibrate the sensor to your boost gauge. Then keep the most accurate values. You will need a DATALOGIT to calibrate with if you want ir perfect.
Cheapy way is to look at what P row matches your boost gauge and change the P row ABS value for the boost you want per row.
41800 offset 0 tworx7
43500 offset 320 ccarlisi
44000 offset 357 pluto
43860 offset 0 lups
Old Aug 18, 2005 | 08:30 PM
books's Avatar
Isn't option 1 in datalogit used for the Apexi Boost control kit/3 bar sensor?
Old Aug 18, 2005 | 10:34 PM
Venom2U's Avatar
I remember reading some where here that option 1 was for the apexi sensor. ................................................? Maybe i could be wrong.
Old Aug 19, 2005 | 01:53 AM
lmt's Avatar
lmt
Newbie
i am using the DATALOGIT program..... just was hoping that someone has the apexi calibrate numbers.. i just dont trust my boost gauge..
more worrie abt the scale then the offset... can easily get it matching on zero. but scale is kinda risky....
any other ideas?
use a pump? which guage should i trust more? or just go buy a boost gauge?
cheers
thanks for the help
Old Aug 22, 2005 | 02:35 PM
cant you just leave the car off and change the offset until it reads zero? Then the boost guage and the pressure sensor for the PFC will both see zero when the car isnt running?
13
Jan 9, 2018 11:19 AM
troym55
23
May 25, 2016 12:42 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
gabescanlon
Sep 5, 2015 12:09 AM
Frisky Arab
Sep 4, 2015 06:17 PM
