My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME
Old Aug 17, 2005 | 11:42 PM
GtoRx7's Avatar
Collections Hold
Well, After 8 months of work, I have the Rx-7 running and pounding down the road. I havent posted anything on it before, wanted to wait until it was close to finished. It does feature cup holders I made, along with a custom stainless 321 header I fab'ed up, 3 to collector, 3.5" the header back, 3, 3.5 inch Borla mufflers, and and dolphin tail section I added on, always wanted one. Any I have a **** load of pics, and a sound video, will post them slowly, as its late at night right now. So enjoy, dont be too hard on me, it not totally finished yet, and the small p-ports arent hooked up yet, and capped off.
Quick info on the setup-
C-series 20b, S5 n/a rotors, race rotor bearings, dynamic balanced rotating assembly, street-port side ports, small semi-ports machined into rotor housings, race port exhaust. 10lbs flywheel, rps 6-puck clutch. full custom intake, machined flange welded on, 55mm throttle bodies from tweak-it, I hand made the air box, full custom garage made header/ exhaust, Microtech Lt-12 computer, stock injectors, Lots of cutom made stuff I did, anodizing of most aluminum, I welded onto the autopower cage, painted by me as well, custom made motor mounts, and ****...blah blah balh, RG coilovers, Kazz LSD, jimlab bushings, ect. ect. ect. Bride seat, omp wheel, takata harness, ahh, too much to list. Check the pics!!
The machinist that made the p-ports and adapter plate ect. does great work, can do p-ports for $250 per housing. Contact me for details, John Holt did the aluminum welding, John holt race cars.
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-early-header1.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-nice-header.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-nice-header2.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-2.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-p-port2.jpg
Old Aug 17, 2005 | 11:44 PM
GtoRx7's Avatar
Collections Hold
some more pic, I gotta alot
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-3.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-4.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-5.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-6.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-center-console.jpg
Old Aug 17, 2005 | 11:46 PM
GtoRx7's Avatar
Collections Hold
more
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-7.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-8.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-9.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-10.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-11.jpg
Old Aug 17, 2005 | 11:48 PM
GtoRx7's Avatar
Collections Hold
and more
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-12.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-12.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-13.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-14.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-15.jpg
Old Aug 17, 2005 | 11:49 PM
GtoRx7's Avatar
Collections Hold
more yet
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-16.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-17.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-18.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-19.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-20.jpg
Old Aug 17, 2005 | 11:51 PM
GtoRx7's Avatar
Collections Hold
moooore
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-21.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-22.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-23.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-24.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-26.jpg
Old Aug 17, 2005 | 11:53 PM
GtoRx7's Avatar
Collections Hold
yep
Attached Thumbnails My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-27.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-28.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-29.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished-rotating-assm.jpg   My rx-7 is done with cup holders! And a 3-rotor semi p-port N/a setup, STOCK SUBFRAME-3-rotor-finished.jpg
Old Aug 17, 2005 | 11:58 PM
GtoRx7's Avatar
Collections Hold
It feels to be about 340- 360 horsepower right now, dyno coming soon. I beat a 04 Z06 corvette, from 80-150, by about 8 car lengths, if that helps any. ALL MOTOR ROCKS!!
Old Aug 18, 2005 | 12:01 AM
sillbeer's Avatar
Looks really nice. I like the air box. When is the dyno day?
-destin
Old Aug 18, 2005 | 12:06 AM
GtoRx7's Avatar
Collections Hold
OH yeah, the motor is using a entirely stock oil pan, not a cut in it, just relocated the oil drain, barely cut the stock subframe for a little clearance. Using a FD S6 front cover, no factory 20b CAS!! Just drilled some holes for the front cover in the oil pan, took 5-minutes. Had to cut off the top pressure feed on the steering rack, relocated it to the side, allowed much lower mounting. relocated the alternator to where the a/c was. that was it, no bump steer, ( Very important in a drift/ road race car) all factory placement. Am I the first?? who knows.
Old Aug 18, 2005 | 12:09 AM
GtoRx7's Avatar
Collections Hold
Hopefully on tues or thursday next week is dyno time. Running on 89 octane is also nice. Oh yeah, it goes to 8,500rpms easily, still has ton of oil pressure, and pulls all the way.
Old Aug 18, 2005 | 01:25 AM
Max7's Avatar
Admitted Sevenaholic
Wow, so this is what you have been up to since I last seen yah.
Amazing, and a few other cool words. Can't wait to see it up close.....
Old Aug 18, 2005 | 10:22 AM
diabolical1's Avatar
what's it like in terms of street manners?
it looks great to me. i love turbos, but i'm a sucker for a nice N/A setup and this is definitely a NICE N/A setup. can't wait to see more pics and video.
Old Aug 18, 2005 | 12:17 PM
RX-Heven's Avatar
I'll blow it up real good
Great setup. That header looks fantastic. I'd like to hear some sound clips of it.
Where is the runner for the semi-p-port on the lower intake? Did you weld on some runners? I just didn't see any pics of how you did it.
You are certainly one up on the rest of us...especially with those custom fabbed cupholders
Old Aug 18, 2005 | 01:02 PM
Jeff20B's Avatar
Lapping = Fapping
That's the coolest 20B header I've ever seen! It makes mine look like a pile of puke.
Old Aug 18, 2005 | 06:42 PM
t-von's Avatar
Rotor Head Extreme
Very nice fab work. I have similar plans for something like this in the near future.
Old Aug 18, 2005 | 07:15 PM
GtoRx7's Avatar
Collections Hold
Streetablity is pretty nice, not full sideport nice, but it idles well, fire up hot or cold every time, still has good torque down low, for daily shifting, but it definitly wakes up at 4100 rpms.
The p-ports are just capped off by the intake flange, so they arent functioning yet. I still need to have some acuators machined up, and a second manifold made off the side. So I am getting all the downfalls of semi-p-port without the advantages. I'm still happy as hell with it.
Old Aug 18, 2005 | 09:46 PM
88fc3sw/HX83's Avatar
Absolutely awesome! I love everything about your setup!
Old Aug 18, 2005 | 11:25 PM
NOPR's Avatar
Rotary Apprentice
shoulda bought a v8! you suck at rotaries! cupholders are for grandmas!
anywayzzzzz...z... riding in this car is amazing. It's sort of weird that its the only FD I've ever been in, but I can tell everyone that it's absolutely nuts. I'll have video clips for everyone later tonight or tomorrow. (brap brap, fireball) also, the passenger seat in this car sucks.
Old Aug 19, 2005 | 02:28 AM
andrew lohaus's Avatar
very impressive!
cool to see someone doing a n/a 20b and semi-pp no less!
and besides, cup holders and a roll cage together just make me smile for some reason
Old Aug 19, 2005 | 03:29 AM
DrunkenGimp's Avatar
Have you weighed it yet? I'm interested in the distribution. Great setup!
Old Aug 19, 2005 | 12:21 PM
NOPR's Avatar
Rotary Apprentice
I made a little video of the car, like a minute and 30 seconds long, but i cant host it. I have a high quality version (350mb), and a low (very low) quality version (27mb), but both are too big for putfile. Anyone who can help me host this should PM me.
Old Aug 19, 2005 | 12:39 PM
NOPR's Avatar
Rotary Apprentice
ah-ha! this video works! It's not of the highest quality, but you can hear the car and see it good enough. Also, the filming from inside the car sort of sucks, but when You're getting whipped back and forth like that in the stock leather seat with the stock seatbelt It's hard to keep the camera pointed straight. Oh well, enjoy!
http://media.putfile.com/LogansFDsmaller
Old Aug 19, 2005 | 12:53 PM
dubulup's Avatar
development
that is one sweet project!! Great work!
Old Aug 19, 2005 | 01:15 PM
hornbm's Avatar
FD > FB > FC
thats wicked!! i wanna see some dyno numbers!
