SMIC w/ stock twins,downpipe,apex intake and microtech comp.
Old Aug 17, 2005 | 07:28 PM
MR.45's Avatar
460mm X 310mm X 85mm
SUPER HUGE 85mm THICK
( 3.25" THICK )
( 18" LONG )
( 12" HIGH )
2.5" INLET AND OUTLET
SUPER BAR AND PLATE
2.5" inlet, 2.5" outlet
i am looking for a smic for my 93 rx7. this intercooler i am looking at above has the inlet and outlet on opposite sides instead of bottom and top. {top inlet, top outlet} is the fatory top and bottom setup better than this one?, or does it make a difference in cooling airflow? this is the link below to the smic i am looking at. please give me any info you may offer.
http://search.ebay.com/rx7-smic_W0QQsojsZ1QQfromZR40
Old Aug 17, 2005 | 07:40 PM
POS7's Avatar
Wankel Shmankel
^ teh suck
Unless you want to use your stock ic duct & fabricate your own piping, buy a name brand one similar to one shown here
http://www.rx7store.net/index.asp?Pa...S&Category=215
Of course, the closest thing is a asp med smic. ~$1200 or so - a lot more expensive but bigger & quality build.
One way to fab a kit is to find someone to buy a duct off of. You can probably use the asp y-pipe crossover pipe to go to the hot side of the turbo. If you have the greddy 3 piece pipe kit, you can probably bend their pipe that leads to the greddy elbow.
This is only an idea I'm throwing out. I have no idea if the asp pipe will mate to the ebay intercooler or if the greddy pipes or duct will fit either.
Old Oct 29, 2005 | 11:45 AM
TwinTurbo_SE7EN's Avatar
resU deretsigeR
there is a newer smic by the same company that comes with pipes nice couplers and t-bolts. and I have your duct right here.
https://www.rx7club.com/group-buy-center-69/gb-fiberglass-duct-xspower-intercooler-ends-11-11-05-a-476815/
sYnth.
Aug 19, 2015 06:27 PM
