Sponsored by: CARiD
overheated tag on re engine.
Old Aug 12, 2005 | 12:48 AM
cmjaure's Avatar
a.k.a. Mike
I am thinking about getting this re engine and the seller says it still has the overheated tag on it does this mean the engine might not be any good or does it mean something else? thanks
Old Aug 12, 2005 | 01:23 AM
RoadRaceJosh's Avatar
Hobby or mental illness?
Those are little tell-tale tabs that rebuilders put on their engines for warranty purposes. If you overheat the engine badly enough that those tabs melt then the rebuilder won't warranty the engine. They really aren't a big deal. What is a big deal is a proper compression test.
Old Aug 12, 2005 | 02:25 AM
cmjaure's Avatar
a.k.a. Mike
thank you ill be sure to make sure it is compression tested. thanks again
Coochas
44
Nov 5, 2019 11:08 PM
Andrew7dg
Aug 6, 2017 01:41 PM
RX200013B
Haltech Forum
Oct 12, 2015 09:45 PM
Rotafuzz
Sep 30, 2015 09:55 AM
Devon Murray
Sep 25, 2015 09:41 AM
