Question about wiring harness connectors
Old Aug 11, 2005 | 05:00 PM
mazpower's Avatar
Slizzard sippin sizzurp
I've got a question about wiring harness connectors...the alternator connector in particular...can I order just the connector from the dealership? Mine is missing insulation from both wires in typical "stock FD wiring harness form" and I'm getting weird charging issues, I wanted to replace this first. I'm pretty sure they have them - I bought a Series 5 alternator for my '87 TII years ago and it came with a new connector and wires - but you know how retarded a Mazda dealership can be in regards to the 7 so I wanted some information from the forum first. If I had a dollar for every time the dealer said a part didn't exist, but they just didn't know where to look in the computer, my 7 project would be more than done by now hehe...
Old Aug 12, 2005 | 02:32 PM
mazpower's Avatar
Anyone?
Old Aug 12, 2005 | 02:36 PM
DaleClark's Avatar
RX-7 Bad Ass
I'd call Ray up - he can find out for sure if it's available. If nothing else, I think that's on the starting/charging harness, which is relatively simple to swap out but I don't know how much the part runs for.
Might not be too hard to find one used. Heck, hit up the junkyard and look through '90s Mazdas - might find one that still has the connector in good shape and you can chop it off.
Dale
Old Aug 15, 2005 | 04:00 PM
mazpower's Avatar
I'll give that a try. Thanks for the help Dale.
Old Oct 11, 2005 | 10:15 PM
quicksilver_rx7's Avatar
Just so you know, in case you haven't found out. You can't order just the connector for an RX-7, but you can order one for a late-model 4cylinder 626 and it is the same one as the RX-7
Joe
Old Oct 12, 2005 | 12:34 AM
IRPerformance's Avatar
Sponsor
Yea you can't order the connectors individually from mazda, and I have never been able to find a source. A good solution I have used is taking an old spark plug wire boot and using it on the alternator wire. You can make it look real clean by slitting the boot with a razor, sliding it over the alternator wire, and the wrapping it with some electrical tape and finish off with some black wire loom.
Old Oct 12, 2005 | 09:00 AM
You can order it. But you have to say to the parts guy, "Hey, I need an alternator connector for a 4cylinder 626". That connector is a "Ford Parts Bin" common connector.
Joe
Old Oct 16, 2005 | 09:24 PM
Here's the part number for the alternator connector, in case someone needs it.
P/N: GD1E-76-MF4
82streetracer
Aug 23, 2015 09:28 AM
BLK 93
Aug 19, 2015 03:47 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
