Haltech Is it possible to use only one O2 Sensor?
Old Aug 7, 2005 | 12:02 PM
hugo20's Avatar
I have a innovate lm1 wideband with BOSCH o2 sensor.
I have the 0-5v output on the wideband, is it possible to use this signal for the E6x and have only ONE o2 sensor? I dont want to have the OEM o2 sensor + the wideband one.
Old Aug 7, 2005 | 12:55 PM
eViLRotor's Avatar
Brother of the Rotary
As long as your LM-1 has a simulated narrowband output, then yes, you can get away with one sensor.
You would connect the narrowband output to the haltech O2 signal wire.
Old Aug 7, 2005 | 03:35 PM
hugo20's Avatar
My 0-5v output is a "Narrowband" output?
What is the voltage of a narrowband output?
Old Aug 7, 2005 | 06:29 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Narrow Band = 0-1v
Wide Band = 0-5v
The LM-1 has a narrow band output for factory ECUs, and should also have the regular 0-5v output for dataloging.
Old Aug 7, 2005 | 08:21 PM
hugo20's Avatar
Originally Posted by Claudio RX-7
Narrow Band = 0-1v
Wide Band = 0-5v
kickass! Tnx claudio.
killerrx710
Sep 28, 2015 09:13 AM
killerrx710
Sep 24, 2015 10:57 PM
rotor_veux
Sep 19, 2015 07:13 PM
