low colant wire where does it go ?
Old Jul 26, 2005 | 01:35 PM
GX7's Avatar
GX7
Newbie
the wire detects from the top of the rad does anybody know where it goes to after that i took the maifolds off and put it back together and now the buzzer wont go off. just thinking i didnt reconect it on the other end or somthing any ideas would be good
Old Jul 26, 2005 | 01:39 PM
ilostmypants's Avatar
Timmaahh
Inside your left headlight....
...j/k I have no idea
Old Jul 26, 2005 | 01:50 PM
WonkoTheSane's Avatar
Green Flameless
I believe it's a solid wire that gets tied into the main engine wiring harness. (the big one), but memory might not be serving me properly.
After consulting my FSM (Wiring section, page 50-40, for those playing along at home) It appears that it goes directly from the radiator, and the only connection then is into the the gauge cluster. it goes radiator connection>harness to gauge cluster>gauge cluster. there's only those two connections in the chain. I do remember that that wire was sorta isolated from the rest, and subject to breaking. I'd guess its' snapped or grounded out on something. Start tracing it back, you should be able to find it, I'd think.
Old Jul 26, 2005 | 02:20 PM
xtremeskier97's Avatar
Originally Posted by WonkoTheSane
.....After consulting my FSM (Wiring section, page 50-40, for those playing along at home)........
LoL....you amuse me when you post
I think you are mostly right. I havent looked under my hood for a while at that wire, but I know it goes from the top of the rad towards the passenger side of the engine bay....and then connects up with the wiring harness (IIRC). Just trace it like Wonko said and see where it leads you.
RexRyder's Avatar
how do u make the noise go away? i got an aftermarket radiator, and threw my stock rad away along with the sensor.
Disconnect the buzzer? But im not sure if that buzzer is ONLY used for the coolant...so let's see what others have to say.
Old Jul 26, 2005 | 02:35 PM
Houstonderk's Avatar
My girl
Just ground the wire. It comes from by the air filter. I found mine had broke but was still hanging on by the insulation.
GX7's Avatar
GX7
Newbie
found the problem there must have been a air bubble in the system i just flushed it all out and put new stuff in and she hasnt buzzed yet. thanks for all your help i guess the buzzer was just doing what its suposed to do let me know when im being a dumbass
Old Jul 26, 2005 | 02:38 PM
TwistedRotors's Avatar
Compression Tester Guy
That buzzer is also for low oil, I wouldn't disconnect it. Hell, I would never run my car without the low coolant sensor working properly, but I guess others will.
-John
Old Jul 27, 2005 | 09:00 AM
RETed's Avatar
LOW COOLANT, LOW OIL, redline - it's all the same buzzer.
-Ted
Old Jul 27, 2005 | 09:34 AM
ah...thanks Ted and twisted....that is definitely good to know.
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
