Need help my car is overheating
Old Jul 25, 2005 | 10:45 PM
squeezy83's Avatar
Newbie
Question Need help my car is overheating
My car is starting to overheat. Im not to mechanically implied so if you guys could help me out it would be greatly appreciated. Where should i start and how much does it cost?
Old Jul 25, 2005 | 10:54 PM
BlaCkPlaGUE's Avatar
I live in an igloo
You can start by checking your coolant level. You can also start by replacing the hosing that goes from your filler neck to overflow bottle, and buy yourself a mazda OEM pressure cap from the dealer.
Also there should be a black shroud that covers the bottom of the engine, its made of plastic and it helps with air circulation to the radiator.
Finally, try searching.
Old Jul 25, 2005 | 10:56 PM
SonicRaT's Avatar
Super Raterhater
Here's what I check for coolant problems:
Leaks (duh)
Air pockets
Faulty cap
plugged radiator
faulty clutch fan
bad ducting
bad thermostat
sherff
Feb 24, 2019 12:09 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
smikels
Aug 18, 2015 01:26 PM
LMBTG
Aug 15, 2015 01:43 PM
