Tach shuts off when i turn car on or goes wild then shuts off after running 30 secs
Old Jul 25, 2005 | 10:44 PM
wthdidusay82's Avatar
Rotary Power
Ok i dont know whats wrong but my tach is being pain, it shuts off right when i turn on the car sometimes and then other times it will be ok for like like 30 secs (sometimes less) driving then it will start bouncing up and down going wild then shut off
(i can shut it off and start it up again and the tach will work again but problem wil just keep happening , either shutting right off or doing the boucing going wild and shutting off) ,
what could this be ? i heard it could be a bad trailing coil but would my car still rev up with only one coil working ? i dont think the coil is bad but i am not 100% sure, i swapped in another trailing coil i had and the tach barely bounced while i turned it over, bounced maybe 2 times before the car starts up ...the other coil makes even steady bounces when turning over just shuts off after it starts or right after being started (30 secs of driving)
the wires for the cas have been cut and are together with electrical tape and there is also a silver wire (ground ? ), that is inside the shielding that is now exposed ... i dont know if this would have any effect on my tach ?
the other thing i was thinking of doing was just buying a cdi box and getting a new tach to hook up to that instead of dealing with all this... i was thinking of going with the crain hi 6 and using it on my leading
i just hope my trailing coil is ok but at this point im just confused, i also have to fix my speedometer..that isnt turning on
Old Jul 25, 2005 | 10:46 PM
SonicRaT's Avatar
Super Raterhater
Faulty coils, faulty plugs, faulty plug wires, faulty wiring, faulty solder points.
That should about cover it!
Old Jul 25, 2005 | 10:47 PM
ddub's Avatar
i am legendary
Have you checked the connection behind the gauge cluster? Maybe it's just loose...
Check the resistance of the trailing coil too, see if it's in spec, also hook up something to it to read rpm while the car is running and see if it is steady or if it's erratic, that might lead you to the answer of its condition.
Fix the CAS wires with more than electrical tape, like butt-connectors or soldering...
Old Jul 25, 2005 | 10:48 PM
twinturbofc's Avatar
Brother of Yeti!!!!!!
Speedo is cable and i had a similar problem with my tach we checked everything trailing coils crank sensor connections etc etc turns out i had a bad wire from my ecu to coils so we rewired a different wire from ecu to the coils. Good luck man
Old Jul 25, 2005 | 11:19 PM
MattMan002's Avatar
For Sale $3000 OBO
when i had this problem it was my coil not bolted down right.... so i bolted it down right and now its not a problem at all.....
Old Jul 25, 2005 | 11:22 PM
Yes i sanded mine as well just to be sure of the contact.
Old Jul 26, 2005 | 12:44 AM
RotaryResurrection's Avatar
Are you on a mission to maintain at least one thread on the main page at all times?
Old Jul 26, 2005 | 12:46 AM
SonicRaT's Avatar
Super Raterhater
Old Jul 26, 2005 | 12:47 AM
Nope but i'm guessing your on a mission to be an ***, Is there a problem with enjoying this forum?? I was unaware that by posting stuff i was bothering people.
Old Jul 26, 2005 | 12:48 AM
felixwankel88's Avatar
*waits for kevins responce*
Old Jul 26, 2005 | 12:50 AM
Yes, and it's been accomplished for years now. And you're here, why, again?
Oh right, your dumb *** thought I was talking about you. I commented in reference to the thread starter, whom I've personally spoken with several times btw.
I assume you can see your way out of our conversation.
Old Jul 26, 2005 | 12:51 AM
Lol nothing like people who like to push people via the net huh huh don't you yankees have a cow to milk or something???? If you don't like my posts don't read them, i like my rx7 and this should be a place to co exist no????
Agent_D's Avatar
rawr
Old Jul 26, 2005 | 12:53 AM
Agent_D's Avatar
rawr
not anymore, you'll find more ******** here than helpful people. not referring to kev or sonik, but others
what a bunch of clowns way to represent rx7 owners.
Old Jul 26, 2005 | 12:54 AM
ddub's Avatar
i am legendary
Calm down ladies
Be nice!
What a shame.
Old Jul 26, 2005 | 01:02 AM
SonicRaT's Avatar
Super Raterhater
LOL, I help this guy more-often than I just laugh at people making fun of him, so I'm still on the good side, right!?
*double checks*
oh ****!
Old Jul 26, 2005 | 01:06 AM
I have been reading up on the 2nd gen section and it seems there is a lot to be learned here, I have posted most of my stuff on the canadian forum and have never had a welcome like this before. regardless the 2nd gen archive has a lot to offer and i look forward to learning from you guys..
Old Jul 26, 2005 | 01:11 AM
**** dude sorry man i just caught on had no idea man ****!!!!!!!!!!
ha ha do i feel a little stupid right now...Sorry guys
Old Jul 26, 2005 | 01:19 AM
I think I have single handedly doubled the length of this thread within half an hour.
Old Jul 26, 2005 | 01:20 AM
I agree plus the entertainment value lmao
Old Jul 26, 2005 | 06:38 AM
RETed's Avatar
WTF just happened?
Did a smell a smouldering flame war erupt, and I wasn't in the middle of it???
doh
-Ted
Kyo
Apr 13, 2019 09:24 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
gtcd
30
Aug 19, 2015 02:44 AM
zuesskroph
Aug 13, 2015 06:05 PM
