Microtech Which TPS do you guys prefere?
Old Jul 23, 2005 | 12:40 PM
Sindregutt's Avatar
I got a T2 and waiting to get my hands in the LT8.. The previous owner said the Stock S4 TPS didnt work very well.. Some suggestion ?
Old Jul 25, 2005 | 12:34 PM
I just got a full range GM TPS from a blazer.
Old Jul 25, 2005 | 06:19 PM
RexRyder's Avatar
the stock s4 tps works fine.
Old Aug 8, 2005 | 09:53 PM
rx72c's Avatar
Top Answer: 1
The standard tps works excellent.
You have to understand that all the tps does is switch from IDLE to LOAD maps.
So as long as it goes over 20% when you hit the accelerator and it goes to zero with no foot on the accelerator then getting a full range tps is going to do jack sqaut.
Old Aug 9, 2005 | 03:39 AM
Sindregutt's Avatar
Ahh okey. Im still using the stock tps and wont change it
Old Aug 11, 2005 | 10:53 PM
bob13bt's Avatar
Fixed the wheelhop
Is it true that a GM TPS can be installed without reconfiguring the Microtech?
Old Aug 11, 2005 | 11:52 PM
10sec rx7's Avatar
yes you can use any TPS you like and dont have to get reconfigured
Old Aug 12, 2005 | 04:33 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
what if you want a throttle pump above 50% throttle?
Old Aug 14, 2005 | 10:00 PM
BOOSTED Vert
depends how you tune and what you use the tps for. IF all you want it for is idle/load switching, then yea you only need the s4 one. But if you tune other things with it, then you want a full range.
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
