Convert NA rear to Turbo II Rear?
Old Jul 22, 2005 | 10:47 AM
sleeper_fc's Avatar
Can this be done? Or, can you build a NA rear to handle 800 ft lbs of torque? Who does this? Price?
Old Jul 22, 2005 | 10:51 AM
RX7Dragon's Avatar
Recovering Rotaryist
800 ft lbs of torque???
Old Jul 22, 2005 | 11:22 AM
Ronald E. Jacques's Avatar
OK, next project...
Wow. I don't think the TII rear would last very long either. Your probably talking major league custom work and/or converting to a live axle.
Any rotary that makes 800 lb ft of torque would surely be making like 1100 hp or more, so are you talking about a V8 swap, and for drag racing only?
Old Jul 22, 2005 | 11:32 AM
RETed's Avatar
Stop smoking crack.
You can't make 800 lb-ft of torque.
Maybe 80 lb-ft of torque?
In that case your stock NA rear will work.
-Ted
Old Jul 22, 2005 | 12:30 PM
gerbraldy's Avatar
wtf's a piston
Yes you can swap a TII rear end into an NA car. It will require that you get TII half-shafts and a custom driveshaft made (If you are using your 6port engine/tranny). If your planning on running under 230hp the NA rear end will work just fine. And I don't think the 8.8" TII rear end (same size as 94-98 mustang gt's) will ever see 800ft.lbs if you have to ask if it can hold the power.
Old Jul 22, 2005 | 03:00 PM
sleeper_fc's Avatar
This is for a V8 conversion
Old Jul 22, 2005 | 03:02 PM
Madrx7racer's Avatar
i suggest a different rear end if you are gonna make THAT much torque....you should't be using RX& drivetrain if you have a V8 with 800lb/ft of torque
Old Jul 22, 2005 | 04:08 PM
sleeper_fc's Avatar
I know, I was just seeing if there was any slight chance I could. I guess I will try to sell both of my NA rear ends. I was hoping there would be a chance to use the 4.10s with LSD in one of them.
Old Jul 22, 2005 | 04:10 PM
naw....not with that power.....might last you a whole 10 seconds......if you pussyfoot it.
Old Jul 22, 2005 | 10:21 PM
RETed's Avatar
Okay, so show us your $100,000 receipt for your motor first and then I'll believe you...
Most V8's have a hard time getting over 500 lb-ft, unless you pour a LOT of money into it.
Putting in an engine that costs more than the car itself is not economical.
-Ted
Old Jul 23, 2005 | 12:08 AM
AUGieDogie's Avatar
if i had 100k for a rx7 it would be a mid engine FD although that might not ne enough money.
Old Jul 23, 2005 | 09:36 PM
sleeper_fc's Avatar
-Ted
Do a search for what a built V8 running 15:1 compression (120+ octane) and a 150 - 250 shot of nitrous can put down.
Economical, no, faster than a rotary in the same car, def. yes.
BTW: There are many companies that sell 600 hp V8s for under $20K.
Old Jul 23, 2005 | 11:20 PM
sleeper_fc's Avatar
Click on this link for an example wise guy
I doubt it will take $86K to make that at 800 ft-lb engine.
Old Jul 24, 2005 | 12:33 AM
RoadRaceJosh's Avatar
Hobby or mental illness?
I just put a TII diff in my '87 Sport for the same reason as you, but I'm only going to be making about 500ft/lbs on spray, but it's not a big motor either. If the guy with the wide-body LS1 powered FC can do run a TII diff and have it live then so can I.
Old Jul 24, 2005 | 12:44 AM
sleeper_fc's Avatar
I agree. There seem to be a lot of V8 guys with a 150 shot of nitrous running the TII rear ends (~500 hp). I do read stories of them going out though too, so I think I am just going to stick with my original plan of a Ford 8.8 - 9" rear end. The cost of the custom work/tubbing is going to break me though!
Old Jul 24, 2005 | 12:49 AM
RETed's Avatar
So how much are 15:1 CUSTOM FORGED pistons?
How about the custom forged crankshaft?
And the custom hand-ported heads?
Race gas?
WTF you messing with STOCK MAZDA DRIVETRAIN PARTS???
So you're building a race-only drag car, and you're not planning to get a Ford 9" or a Dana???
You gotta be kidding me right???
Faster in the 1/4-mile?
Maybe.
Faster in a road race track?
I doubt it.
Sure, but you're telling me everything else is FREE?
Setting up a 800 lb-ft drag car is not trivial.
In fact, there are probably only a handful of people on here who know how to do it or competent enough to design something like that.
Do it wrong and you're going to end up in the wall.
You're just asking the wrong questions, which means you have no idea what you're doing or this is all a pipe dream...
-Ted
Old Jul 24, 2005 | 01:02 AM
sleeper_fc's Avatar
Race gas?
Maybe.
I doubt it.
-Ted
You are right, I don't know much about it, but my mechanic does he just happens to have a 9s street car and a 7s race car. I was just trying to find out if there was a cheaper way to do it. All I am trying to do is run a 9.4s pass, which means if I don't have to spray to do it that is fine with me. I just want a rear that can handle the power if I spray.
Since you are so cocky about my pipe dream, how about we put some money on it? Furthermore, if you don't have anything pertinent to say regarding my initial questions, how about you post in another thread.
Old Jul 25, 2005 | 02:56 PM
so YOU'RE not building it? what's the fun in that?
Old Jul 25, 2005 | 04:06 PM
digitalsolo's Avatar
RX-347
Bah, I have 800 lbs/ft of torque in several vehicles around my family...
They're called DIESELS!
Seriously though, you're not likely to keep that rear in one piece, and if you do, axles are going to be trouble next, you should really look into a Ford solid axle, and a 4 link, if you're talking all drag.
In regard to making more then 500 lbs/ft cheap in a V8. My LS1 should be 550 or so (on spray), and I've got less then 2000 in the engine/trans total. Just gotta shop smart. When I do the turbo setup, it'll likely be well over 600, and I'll still have less then 4000 in it.
Not saying you can't do that with a rotary (or even do it in that price range if you're so inclined to design parts yourself). Just noting a V8 can do it with relative ease if properly designed. Heck, my Buick V6 can make 800 lbs ft. for WAY under 10K dollars invested, and do it for quite a long time at that-
Old Jul 25, 2005 | 04:38 PM
If you plan on making 800 ft/lbs I don't think the 8.8 is going to last long and the 9" will need a good nodular case, a spool or locker and a fabricated housing.
Have you asked your mechanic what it's going to cost to meet you 9.4 second 1/4 mile ET goal? If you think the back-half chassis work is going to be expensive you'll positively **** once you see what the rest of the car costs.
Old Jul 26, 2005 | 01:39 AM
sleeper_fc's Avatar
You are right, I am getting a detroit locker. As far as the total build we have estimated $17K more on top of the car, engine and nitrous kit that's why I am trying to see if there are ways to cut costs.
Old Jul 26, 2005 | 02:09 AM
Tournapart's Avatar
RIP Icemark
this forum seems to be REted's life. it pisses me off that every other thread i read he seems to ripping on someone just looking for a simple answer.
Old Jul 26, 2005 | 02:11 AM
Aruba27flr's Avatar
hehehe, you could just weld the gears. that's always fun, plus people know you're putting down power when you make turns. you might want to go with dana 60s for that though... my friends and i have blown stock toyota axles a few times that way with only 104 hp and 135 lb ft of torque... of course the truck had 5.88 gears, dual t-cases (first t-case: standard 2.1:1 second: 4.7:1) and both were in 4wd low. yes, i like spending money on cars, but that was just getting too expensive. if you hold down shift, 4x4 = $X$.
Old Jul 26, 2005 | 03:15 AM
RETed's Avatar
It's not a "cheaper way to do it".
Sure, how about you build it...run a time slip...get it on a dyno when it hits 800 lb-ft, and I'll eat my words.
How about $100?
Is it worth it to you?
-Ted
Old Jul 26, 2005 | 04:17 AM
rarson's Avatar
Does that $17k include a driveshaft loop, scattershield, safety harness, roll cage, parachute, and fire supression system required for a 9-second vehicle?
