sueaking clutch pedal??
Old Jul 21, 2005 | 09:41 PM
speed_monkey's Avatar
affen
It just started tonight. When I press in the clutch pedal it makes a weird squeaking noise, I will go look at it tommorow when I can see what I'm doing. Mabey some lube? Anyone else's clutch pedal do this?
Old Jul 21, 2005 | 09:59 PM
Stanello's Avatar
backslash beanbagrace
Mine started it back in April or so, too lazy/forget to check it out.
Old Jul 21, 2005 | 10:04 PM
jono20's Avatar
mine does that too.
Old Jul 21, 2005 | 10:11 PM
86gxl_fc's Avatar
i think that squeeking is coming from the pressure plate. dont think i need to explain how the pressure plate works.
Old Jul 21, 2005 | 10:14 PM
Smoken''s Avatar
try lubing your clutch disk
Old Jul 21, 2005 | 11:10 PM
AcidShock's Avatar
Eet fase
Mine does it to. It was gradual and it is definately not the pressure plate. The clutch pedal is on a roller and I believe that is what causes the squeaking. Get some lithium grease and see if that fixes it.
Old Jul 22, 2005 | 03:43 AM
Nipples
graphite should help if you can get to the bushing. The correct thing to do is just replace the bushing for the pedal. It is a pretty common problem on cars.
Old Jul 22, 2005 | 07:42 AM
RETed's Avatar
Mines started doing this a few months ago.
Maybe clutch master is dying?
-Ted
Old Jul 22, 2005 | 12:24 PM
ilike2eatricers's Avatar
I R SAD PANDA W/O BAW
Mine has been squeaking for the last few months intermittently, been too lazy to check it out as well.
Old Jul 22, 2005 | 06:37 PM
Nipples
Well, if you guys can hear it loud and clear from your pedal box assembly, then I would think it would be a pivot bushing. I've never heard of a dying clutch master cylinder squeaking before it bit the dust, but hey, there's a first for everything.
Old Jul 22, 2005 | 10:01 PM
Therotaryrocket85's Avatar
Back when i had my se it developed an intermittent squeak from the master cylinder. I rebuilt it and the metal shaft inside it with the rubber bushing on it chafed on the inside of the master cylinder causing it to sqeak. I ended up just spraying a light coat of wd40 in it and that solved the problem. Be careful though cuz if you put too much lubricant in there then the master cylinder tends to loose its seal and you will find your clutch engaging at stop lights. I learned the hard way.
