TII brakes on 91' N/A: Help needed
Old Jul 21, 2005 | 04:39 PM
SkaterAJR's Avatar
Right now im in the market and soon going to buy a full set of TII brakes (calipers, rotors, and pads) that I hopefully will be installing on my 91' N/A coupe. From what i've read, the TII brakes bolt directly onto the 91' nubs. Im just woundering if I am correct or will I need to buy a set of TII hubs (please say I dont). Also, if theres anything eles that I need to complete this swap.
-Thanks, for the help, Andrew
Old Jul 21, 2005 | 06:13 PM
SkaterAJR's Avatar
anyone, anyone?
p.s. that word after 91' should be "hubs"
Old Jul 21, 2005 | 06:16 PM
RX7Dragon's Avatar
Recovering Rotaryist
All you need for the swap are the calipers and rotors. You got 5-lug already so your all set there.
Old Jul 21, 2005 | 06:17 PM
Crazyt's Avatar
Over Macho Grande?
soft brake lines as well
Old Jul 21, 2005 | 07:34 PM
cprx7's Avatar
aka Underdog
why do you want to do this swap? are TII brakes an upgrade over the '91 N/A's ??
Old Jul 21, 2005 | 07:44 PM
RX7Dragon's Avatar
4 piston front brake, vented rear brakes from the T2 are alot better than the single piston front non-vented rear stock NA brakes.
Old Jul 21, 2005 | 08:01 PM
cprx7's Avatar
aka Underdog
that's odd.. I know for a fact my '91 N/A has 4 piston front brake calipers. I can't remember right now if the rear are vented or not though.
Old Jul 21, 2005 | 08:24 PM
RX7Dragon's Avatar
Verts have the 4pots on the NA's, yours a vert?
Old Jul 21, 2005 | 08:49 PM
JerryLH3's Avatar
Rabbit hole specialist
Four piston front brakes were available on N/As on one of the upgrade packages. My 91 N/A had the four piston front brakes. It doesn't have to be a vert for it to be an N/A with four piston front brakes.
Old Jul 21, 2005 | 09:06 PM
37FC3S's Avatar
SSDD
Get stainless steel brakes for a TII(Soft Lines). You will also need the hard lines that go from the calipers to the struts. You can order them from a dealer for around $16
Old Jul 21, 2005 | 09:11 PM
cprx7's Avatar
aka Underdog
Sounds like JerryLH3 is correct since mine is not a vert
Old Jul 21, 2005 | 09:17 PM
BOOSTED Vert
on my 91 it came with 4 piston brakes in the front.
Old Jul 21, 2005 | 09:42 PM
JerryLH3's Avatar
And if you look at Icemark's sticky "What did my FC come with?", his scans of the factory brochures state the same thing.
Old Jul 21, 2005 | 10:03 PM
lnlycrpr's Avatar
always searchin
Red face
I have a 91 GXL and have 4 pot fronts and vented rears. I found this out the hard way when I was buying rear calipers. I have a set of non-vented calipers "brand new" for sale if you need. I think that is pretty much the standard on brakes unless you have a 4 lug. I could be wrong though?
p.s. No i did not swap the TII brakes or anything, they were stock on my GXL
Old Jul 22, 2005 | 09:50 AM
SkaterAJR's Avatar
Hey srry im already buyin vented rears from somone eles, but thank you anyway. One more question though, the short hard lines from the caliper to the shock, do i need that for the front and rear? Asking because I just called the dealer and they said the front ones would be $13.52each(no problem) and the rear ones would be $54.87each(damn expensive). Is is possible to get away with using the SS lines im buying(for TII calipers) and the stocks hard lines of my N/A rears. Thanks for the help.
-Andrew
p.s. thanks to everyone who has posted, lots of good help
Old Jul 22, 2005 | 04:30 PM
JerryLH3's Avatar
You'll need the hard lines for the front only. Add the SS lines (front and rear) for a four piston setup and you're good to go.
Old Jul 22, 2005 | 04:43 PM
RockLobster's Avatar
Let's get silly...
I did this conversion earlier this spring. At a minimum you need:
1. Front 4-pot calipers
2. Rear vented rotors
3. Rear calipers for vented rotors
4. Hardlines between the flex lines and the caliper for the fronts
Rear pads are the same, front pads are different.
The rear hard and flex lines are the same between the setups (on the S5 anyway)
Im not sure if you can reuse the flex lines on the front but since you are getting braided stainless lines for the 4-piston setup you dont need to worry about it.
its a very straight forward install. the above only applies to S5 cars
Also they did not have a GXL in 91
Old Jul 22, 2005 | 04:48 PM
Let's get silly...
If you have 4-pots on the front from the factory you have vented rear rotors.
Frisky Arab
13
Aug 18, 2015 05:30 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
