is this bad?? please help!!!
Old Jul 21, 2005 | 01:05 PM
slow_2ed_gen's Avatar
last night i was filling up with oil, i put the filler cap on crooked and when i took it off two small pieces of the plastic thread cracked off and fell in to the oil neck. how bad is this for the car?
Old Jul 21, 2005 | 01:26 PM
Aaron Cake's Avatar
Engine, Not Motor
Not a big deal. They will never be sucked up by the pump since it has a filter screen. Likely they will come out with the next oil change.
Old Jul 21, 2005 | 01:32 PM
MrFuzzy's Avatar
Damn Right It's Me
On kinda the same topic when i take my oil cap off while the car is running weird noises come from the filler tube
Old Jul 21, 2005 | 01:37 PM
Aaron Cake's Avatar
Engine, Not Motor
You're hearing the movement of the eccentric shaft, oil pump, splashing of the oil, and the vacuum that the intake is sucking through the purge valve.
Old Jul 21, 2005 | 02:30 PM
ska3260's Avatar
when those plastic bits are in the pan they are floatig around. If you are like me and get on your car hard with your lead foot, you could possibly run into oil pressure problems if the peices are sucked up and clogg up the screen. But if the oil pressure is good then go ahead with it just keep a close eye on the gauge.
Old Jul 21, 2005 | 02:31 PM
Aaron Cake's Avatar
Engine, Not Motor
You would have to have a LOT of plastic to starve the pump. The pump pickup screen is huge.
Old Jul 21, 2005 | 02:35 PM
ska3260's Avatar
that is true but what else is down there, how many miles are on the car and what else has the oil system brought by (if the oil filter went into bypass mode). But like I was saying if the gauge readings are ok and you feel up to it then let it ride. If it was my ride i would be doing and oil pan gasket tonight.
Old Jul 21, 2005 | 02:37 PM
ska3260's Avatar
miss read this, yea change the oil see if they do flush out, get down there with a strainer and pull the plug and see what you get.
Old Jul 21, 2005 | 03:16 PM
MrFuzzy's Avatar
Damn Right It's Me
It just recently started doing this, is that a bad sign?
squirrels
Sep 1, 2024 09:52 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmolina0163
Oct 3, 2015 10:04 AM
Jmpabon93
Sep 30, 2015 04:57 PM
