Sponsored by: CARiD
wierd...
Old Jul 20, 2005 | 02:54 PM
RX-17's Avatar
wierd...
i dont really know wut to say but just read...
http://www.mototuneusa.com/break_in_secrets.htm
Old Jul 20, 2005 | 03:38 PM
johnnyg's Avatar
That seems oddly logical!
I was taught that you should take it easy because the rings will chatter against the honed cylinder wall and might actually break. But I also recall the break-in procedure for an '99 Grand Prix GTP I had which was similar to this "secrets" technique. The manual said that it's best to avoid staying at one speed, suggesting you accelerate quickly, then engine brake. Or something to that effect.
Old Jul 21, 2005 | 01:53 PM
RX-17's Avatar
hmm i find it quite interesting. With everything that he says it sure seems that its really logical but i dont know how true his facts and statements are. Do you think it could hold any ground for rotaries?
Old Jul 22, 2005 | 11:12 AM
johnnyg's Avatar
Well, if it really does help piston rings seal better, then I suppose it would help with a rotary too. But I still question this whole thing. If expansion pressure really does force piston rings against the cylinder wall, then where does it go after that? Wouldn't there be blow-by into the oil pan? How could the gas get behind the piston ring, but not past it?
Regardless of that, if pressing an apex seal against the housing wall would help with sealing (and it seems obvious that it would), then centrifugal force would certainly do the trick with a rotary. And that means high RPM. Which is exactly the opposite of the "standard" break-in procedure for a new motor!
I still think chatter would be the real enemy here, but I'd love to be in a position to test the theory!
Old Jul 27, 2005 | 02:34 AM
locketine's Avatar
Road Rotary Aviator
well for a rotary, as I understand, the break-in is just wearing the seals into their respective grooves. Why you can't go high rpm I would imagine is because our rotors are basically banging around inside the houring and the aprx seal is there to absorb that force, but if they aren't fully seated such a situation could very well dislodge the seal or dent something. Same for going WOT during break-in, except it's the explosion you're worried about then.
Old Jul 27, 2005 | 09:20 AM
johnnyg's Avatar
Banging around? The motion is geometrically perfectly smooth. And, all 3 tips of a rotor are continuously in full contact with the housing, so I don't see how you could dislodge a seal.
dsanches
May 21, 2012 09:43 AM
NAN777
11
Dec 23, 2007 10:31 PM
Noodlebut
Jan 2, 2005 12:48 PM
