*The Life of Coilovers?
Old Jan 10, 2002 | 11:54 PM
0piston's Avatar
I am in the market to buy some coilovers soon. What is the average lifespan of a coilover from street/track use before the shock/strut starts leaking? Being not able to rebuild them really makes a valid point when you're basing a buying decision. i.e. HKS, Apexi N1s
Old Jan 11, 2002 | 01:52 AM
MastaCow's Avatar
Not sure about the lifespan, but these are worth checking out..
www.advance-design.com
I believe M2 may market a version of these for the 3rd gens.
Old Jan 11, 2002 | 12:32 PM
HedgeHog's Avatar
Rotary Poseur
i think that may depend on the individual dampers. The Penske Technical Manual sez to do the following every 30 hours of track time or annually: change oil, replace the shaft seal o-ring, wiper, shaft bearing o-ring, reservoir cap o-ring, piston o-ring, floating piston quad ring and valve shims.
Hmmmm....what did i get myself into?
Old Jan 12, 2002 | 01:04 PM
Trout's Avatar
Yes, M2 does sell these and I highly recommend them. I've had mine since last July. They were $2100 back then I think $2400 now but at least you know what you're getting vs. the Japanesse brand coil overs. For the money, the Apexi, HKS, etc. are too much of a gamble.
The M2/AD are easily rebuildable, you can buy a single corner if damaged, the Eibach ERS springs are readily available for changing spring rates, they come with upper pillow mounts. Do a search, there are a few people on the Forum running this set-up.
Not sure how often they require rebuilding or service but the manufacturer (Ground Control) can be contacted easily to find out.
Jack
Old Jan 13, 2002 | 01:33 AM
0piston's Avatar
Thanks guys!!! Hedgehog with the money of those you could of got a neon
Old Jan 13, 2002 | 02:21 AM
HedgeHog's Avatar
Rotary Poseur
But i can't fit a Neon in my wheel well.
Old Jan 16, 2002 | 01:14 PM
riffraff's Avatar
smog nazi destroyer
i am going to play ignorant here for a while. what are coilovers, and what do they do?
Old Jan 16, 2002 | 02:15 PM
SleepR1's Avatar
Cool Read this thread from the very beginning, or do a search on coilovers
No Text
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
James Knox
Oct 22, 2015 05:08 PM
