2nd Gen -- More "finicky" than 1st Gen?
Old Jan 10, 2002 | 11:00 PM
pjr's Avatar
pjr
Mr May 2011
Here's the post. Damn this "busy serve!"
In reading the forum, it seems that the 2nd gen RX-7 is a much more finicky car than the 1st gen. Based on the posts, there are a lot of unique problems that occur on 2nd Gen cars (e.g. flooding, turbos, electricial issues). Anyone have thoughts on this?
Old Jan 10, 2002 | 11:01 PM
BiG WaNkLeR's Avatar
good stuff going on here
Old Jan 10, 2002 | 11:02 PM
nevermind
Old Jan 11, 2002 | 12:53 AM
Felix Wankel's Avatar
Super Newbie
The FC's have a lot more electrical bugs than the FB's.
Old Jan 11, 2002 | 01:19 AM
Icemark's Avatar
I think the SA/FB is pretty much the same as a FC as far as overall reliabilty. Its just different things go wrong on a SA/FB than a FC (or for that matter a FD).
Like SA models often have points probs, choke probs, fuel pump, rust, etc while the FC its often things like cold solder joints in brains (which the SA/FB doesn't or has in limited numbers), clogged leaky injectors (common if the fuel filters are not changed when required) that cause flooding, and other minor things.
Although I do think the plastic used in the FC (and FD) is not as good quality as the SA/FB.
Old Jan 11, 2002 | 07:11 AM
Josepi's Avatar
Despise Enmity
FB-had problems with choke\solenoids going bad\ACV\shutter vavle (carbed 12As)\TPS (13B)\noisy LSD\
FC-wiper switch\shifter bushings\turbos (I love mine though, I wouldn't trade it for a 250 HP FB)\OMP (more so in S5)\switches\crappy plastic
They all have their problems, and benefits. I love my FB cause it's light, I love my FC because it's mucho faster.
So if the question is more finicky, the answer is no. Just different common problems.
Old Jan 11, 2002 | 09:59 AM
j9fd3s's Avatar
Community Builder
the turbo fc's are definatly pickier, everything has to be just right in order for the car to even idle, the first gens will just idle high
mike
Old Jan 11, 2002 | 11:02 AM
Josepi's Avatar
Despise Enmity
mike
not true for the carbed ones. I had a vacuum leak on this one hose and the damned thing wouldn't hold an idle after the choke cut off. Fixed the hose, fixed the idle.
