i want to see if my stock A.B.V (BOV) is leaking, can I just take it off?
Old Jan 10, 2002 | 06:57 PM
legendr35's Avatar
would that have any adverse effects on the car? thanks
Old Jan 24, 2002 | 03:48 PM
94RXMAGEE's Avatar
The bov is closed by pressure when the car is under acceleration if you took it off the boost would just leak out into the air so your turbos would be working very hard to keep the boost up, I would not suggest taking it off. When your off the gas the vacum opens the valve and releases the pressure. I would say try borrowing someone eleses, or buy a used one, I did for $18.
Old Jan 24, 2002 | 05:48 PM
puma's Avatar
canadian monster
yes you can do that but make sure that you plug the hole so that air won't leak.
Old Jan 24, 2002 | 09:38 PM
alwan16's Avatar
take it off and test it. you will need a vaccuum pump/tester though that you can buy at the autoparts store. use the instructions on this page:
http://home.istar.ca/~dvandit/turbocharger.htm
Old Jan 25, 2002 | 12:07 AM
Swamp RX-7's Avatar
Get a new BOV if the old is dying. Removing the BOV will cause turbo-surge and shorten the life of your turbos
Old Jan 25, 2002 | 12:20 AM
efiniracing's Avatar
Really it's only $18? at the dealer or what?
msilvia
28
Apr 14, 2016 12:58 PM
