Microtech Boost controller for a LT8
Old Jul 15, 2005 | 01:11 PM
Sindregutt's Avatar
Wich boost controller can i use with the LT8?
Old Jul 16, 2005 | 10:04 AM
fastcarfreak's Avatar
3rd motors a charm I hope
Any boost controller will work. Boost control, has nothing to do with the ecu.
Old Jul 18, 2005 | 07:25 PM
a10secstreetcar's Avatar
But I thought the boost is controled by the lt8 my is...
Old Jul 25, 2005 | 03:13 PM
jeyjey's Avatar
I have just got an E-BOOST by turbosmart to use with mine
This is the only one that controls boost creep that I know of. Providing you have an external w/gate
Old Jul 26, 2005 | 12:06 PM
TwistedRotors's Avatar
Compression Tester Guy
Boost creep is caused by the wastegates inability to flow enough exhaust around the turbine if I'm not mistaken, I'm not sure how the E-Boost can claim to control that. It is a very nice closed loop controller though as far as I have heard and on my list for future upgrades. Right now I'm just running a Profec B Spec II which is basically just a glorified bleeder valve type controller.
-John
Old Jul 26, 2005 | 01:12 PM
jeyjey's Avatar
I was under this impression from a couple of freinds that work at AET TURBOS in the u.k. they suggested to get this unit over other units as they have had problems in the past with other units.
I had problems in the past with my apexi but that was also with standard ECU,turbo-wastegate etc.
If I am correct they said something about this unit being more efficient in controling the W/gate.
From looking at the manual its a lot easier to setup than the apexi too and it has 3 presets as opposed to 2.
Old Jul 26, 2005 | 03:50 PM
Broken09's Avatar
I am becoming...
I'm using the Profec B Spec 2 without any issues
Old Jul 26, 2005 | 04:06 PM
13btnos's Avatar
Best money can buy well worth it. http://www.innovativeturbo.com/cgi-b...99920716680406 Best pricing on this controller http://www.paradiseracing.com/Main.htm owners name is Luis email him or give them a call.
Old Jul 27, 2005 | 10:04 AM
Ive heard good stuff about the Joe P Manual boost controller
Old Jul 27, 2005 | 04:50 PM
silverrotor's Avatar
I am using Blitz Dual-SBC Spec S with no Issues.
Really, It doesn't matter which Boost Controller you use...It's ran mutally exclusive with the MT.
Old Jul 27, 2005 | 06:07 PM
Sindregutt's Avatar
Where do you connect the boost controller to the LT8?
Old Jul 28, 2005 | 01:48 PM
You don't. The LT8 and a boost controller will work completely seperate from each other.
-John
Old Jul 28, 2005 | 06:02 PM
Sindregutt's Avatar
Ahh, misunderstood something.. but it was like i thought in the first place :P
rgordon1979
40
Mar 15, 2022 12:04 PM
AXA
Sep 5, 2015 10:06 AM
