Microtech factory t2 microtech settings anf TPS question
Old Jul 8, 2005 | 01:26 PM
need-a-t2's Avatar
well i have a LTX8 and since i have gotten it (used) i think i may have screwed with the settings enough so that the car does not start any more. does anyone know if there is a website or a past post that has all the original settings for a t2? i want to start from scratch and work from that.
also, does anyone know if you can change the input voltages for the TPS? i'm trying to use a FD TB with the full range TPS on the T2 progaming, but it only reads up to 43% throttle when i have the plates all the way open. thanks
Old Jul 10, 2005 | 03:36 PM
need-a-t2's Avatar
no one? how about just idle and crank settings?
Old Jul 11, 2005 | 03:12 AM
surfpac's Avatar
You have to recalibrate your TPS then do a search on this forum for "base map" and load these numbers in.
Old Jul 12, 2005 | 05:48 PM
silverrotor's Avatar
Have a look here to get you started.
https://www.rx7club.com/forum/showthread.php?t=343297
smikels
Rtek Forum
May 12, 2016 12:34 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Marty RE
Aug 13, 2015 11:19 AM
