coolant prob
Old Jul 8, 2005 | 07:28 AM
revv_head's Avatar
"Sweet Homeee, RX-7!"
coolant prob
hey my RX-7 was getting really hot when i drove it i took it to the mechanic and he said the water pump wasnt working but i dont have enough money to fix it i am an aprentice mechanic only 1 mnth even though free labor still not enough money anyway i noticed if i revv it to 5500rpm it starts spinning but when im driving and it drops below it stops and heats up can i do this or is it bad for the motor the keep it above 5500rpm thats what im doing now thanks it uses a **** load of gas like this though.
ps soz dis is abit jumbled im really tired
NAthan
Old Jul 8, 2005 | 09:00 AM
brownmound's Avatar
Anytime baby!
Punctuation....use it dude.
The first repair I ever made to the Mound was replacing the water pump, and I had zero car repair experience prior. Get a Haynes manual and go for it. The water pump is about $30 at the auto parts store.
Right on.
Old Jul 8, 2005 | 09:03 AM
rotarycrazy's Avatar
Leave my avatar alone!!!
I would definatly would not be risking tryving a 7 when the pump is not working. Borow some money if you need to becouse if you oveheat it your motor is done for and then it will cost you a **** load more money to get it fixed.
Old Jul 8, 2005 | 09:04 AM
trochoid's Avatar
Old Fart Young at Heart
You have 3 choices. Fix it. Park it. Drive it and replace the engine. You pick the one that works best for you.
Old Jul 8, 2005 | 11:15 AM
rxtasy3's Avatar
Originally Posted by revv_head
i noticed if i revv it to 5500rpm it starts spinning but when im driving and it drops below it stops...
NAthan
u can tell this while driving it? is the belt tight?
Old Jul 8, 2005 | 12:11 PM
Yark79's Avatar
How does he know the water pump isn't spinning? Have you removed your air pump? Are there two belts running over the water pump pulley? I think two is a must.
Old Jul 8, 2005 | 08:07 PM
revv_head's Avatar
yeah i pulled it apart and cant move it and i can feel when it stops spinning the engine note drops and it struggles
Old Jul 8, 2005 | 08:13 PM
revv_head's Avatar
Heres the Punctuated Version
I pulled the water pump apart and tried to turn it i can't and i can feel with the engine sounds and power that its stuck aswell i know this by removing belts and listening to engine sound and at 5500 rpm its normal so i have no idea what to do i have to drave to the country in 3 days and i dont want to drive it at over 5500 rpm the whole time because it will overheat anyway Thanx.
Nathan
Old Jul 9, 2005 | 02:07 PM
hanman's Avatar
That's the puncuated version?
You're crazy if you drive that car without replacing the pump. I have better uses of $2K US than to spend it on an engine that I mistreated.
Old Jul 9, 2005 | 04:40 PM
trochoid's Avatar
My best advice is to put a for sale sign on it and sell it before you totaly destroy it. Over heating a rotary once can toast an engine.
I still stand by my first post in this thread. Park. Fix it. or Drive it and replace the motor. There is no way around the 3 choices, don't be thick headed, unless you can afford it.
Old Jul 9, 2005 | 06:43 PM
hanman's Avatar
ditto
Old Jul 9, 2005 | 09:20 PM
Rx-7Doctor's Avatar
Talking Water pump
Tripple ditto. No offense but if you can't afford $30-$40.00 in repairs maybe you should consider another form of transportation. Perhaps a Kangaroo
Old Jul 10, 2005 | 07:35 AM
Kentetsu's Avatar
And perhaps the kangaroo can explain punctuation while you are riding it to work....
Old Jul 10, 2005 | 08:33 AM
Fire85GSLSE's Avatar
Chad Carson
NAthan
Come on are you kidding? No, do not drive it like that. If you over heat the motor than the $30 it would have cost you to replace the water pump just jumped up to a motor rebuild. **** man use your brain on this one. Rotories do not like to over heat!
The money your spending on the **** load of gas, use it to replace the water pump. It is a very simple process and a easy install!
DO NOT DRIVE IT AT ALL THE WAY IT IS UNLESS YOU HAVE MONEY FOR A REBUILD!
Hope this help you see the light.
I tell you what, sell the car to someone that will enjoy it and take care of it before you trash it.
You need a truck with a bullet proof straight six in it. Those will run not matter what you do to them or what stupid things someone wants to try on them.
Old Jul 10, 2005 | 11:56 AM
LongDuck's Avatar
84SE-EGI helpy-helperton
As an interesting aside, Revv Head is in Australia and it's winter there right now.
He's going to have a serious problem when it starts to warm up there again!
Preventative maintenance will save you a lot of time and headaches - highly recommend replacing that water pump before it kills the engine and leaves you stranded in the middle of nowhere. Where I live in AZ, this kind of thing can get you killed if you drive on less populated roads...
Old Jul 11, 2005 | 02:21 AM
revv_head's Avatar
hey i fixed it (pay check came in) it runs well i used my money on a Twin Turbo and inter cooler plus i brought my first house 560,000 bucks pluss 2000turbo pluss when i brought the car i had to put a new engine in 4000 buck so i think it speaks 4 its self when i dont have enough money to fix it.
Old Jul 11, 2005 | 08:57 AM
hanman's Avatar
You were the one that said you didn't have any money to fix it. Not us.
I find it amazing that after all the money you dropped in the car, that you would even consider starting the thing with a bad water pump. You say you are an apprentice mechanic? I think you need to go back to auto mechanics common sense 101.
Old Jul 11, 2005 | 01:00 PM
Rx-7Doctor's Avatar
Old Jul 11, 2005 | 01:24 PM
Eriks85Rx7's Avatar
Wheel Revolutionist!
wtf u can put a twin turbo rotary engine a FB but you cant fix a water pump?
Old Jul 11, 2005 | 02:25 PM
trochoid's Avatar
I smell an adolescent troll.
LongDuck
Oct 7, 2015 08:12 PM
musker
Oct 1, 2015 05:58 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
