So i Got an S5 slight idle problem
Old Jul 7, 2005 | 02:01 PM
rx7ofdoom's Avatar
hey, well i got an rx7 put down the deposit and he's smogging it this week. The only problem with the car was that at idle it was a little rough was and stayed fluctuated at about 500rpms. When i put A/c on it idle perfectly at 1000rpms what could be wrong? Besides that its great im thrilled!
Old Jul 7, 2005 | 02:57 PM
Icemark's Avatar
needs a tune up and TPS adjustment
Old Jul 7, 2005 | 06:57 PM
rx7ofdoom's Avatar
I have a good amount of previous auto experience what sort of service manual should i look to invest in to see how to do maintenance on this car? also I read about making a tps tool with 2 turn signal lights but can't seem to remember where perhaps you know thanks.
Old Jul 7, 2005 | 07:01 PM
Icemark's Avatar
much simpler with a multi-meter, and many people damage the ECU's output by doing the bulb thing wrong.
Here this is very straight forward:
http://www.fc3spro.com/TECH/HOWTO/TPS/tps.html
Old Jul 7, 2005 | 07:14 PM
rx7ofdoom's Avatar
cool already have a multimeter thanks! gonna check out that link now. Im picking up my car on saturday and ill get right to work ,
read it so adjust it till the multimeter reads 1ohm at idle?
also whats WOT mean? (wide open throttle?)
Old Jul 7, 2005 | 08:07 PM
KompressorLOgic's Avatar
I
i used the multi meter method and it seemed to work much better then when i did the light bulb one.
Old Jul 7, 2005 | 08:26 PM
Icemark's Avatar
yep WOT is Wide Open Throttle.
Many of the common abbreviations are found in the FAQ for FC sticky thread at the top of this section
Old Jul 8, 2005 | 04:19 AM
rx7ofdoom's Avatar
cool i looked threw it alot of good info.
Old Jul 9, 2005 | 02:10 PM
rx7ofdoom's Avatar
hey, i just noticed thats for TII i have a n/a same procedure?
Old Jul 9, 2005 | 03:37 PM
rx7ofdoom's Avatar
well i didn't adjust tps yet but i did tighten the throttle cable it was loose now it idles well at stops but when i change things it seems to shutter a little
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
rx7shirley
Sep 2, 2015 02:11 PM
