What should i do to a j Spec motor 13b REW
Old Jan 9, 2002 | 03:59 PM
Im getting a Jspec 13b REW motor. since its going to be out the car already what should i do to it?
My mods are apex FMIC, Koyo radiator, Fluidyne oil coolers, pettit unlimitted ecu, GReddy sp exuast.
Old Jan 9, 2002 | 04:02 PM
vosko's Avatar
Just Call Me Terminator!
i would have the engine torn down if you have the money and have it street ported, coolant passage ported, etc and checked for wear on the housings. you never what happened to that engine in japan... could of been beat to hell. better to do it right the first time
Old Jan 9, 2002 | 04:30 PM
How much would that run for? And Who around my way can get it done?
Old Jan 9, 2002 | 04:38 PM
vosko's Avatar
here are a few local shops
www.rx7s.com T/R
www.jrsrotaryperformance.com (down at the moment)
www.kdrotary.com
these are all local shops. if you need more info IM @ vosko
Old Jan 9, 2002 | 10:03 PM
Mac's Avatar
Mac
J-spec engine
When my '94 original engine blew a seal at 68K I purchased a <30K miles J-spec RX7 engine (97 we think) not a Cosmo. It is a real strong engineand turbos. Pettit racing installed it out of the crate with only a couple of minor changes.
The upper intake manifold and throttle body on the J-spec are a little different so we used the original '94 components, including the rats nest.
The J-spec engines typically don't have a EGR valve which is not a problem unless you (1) need it for smog test or (2) you have a '94 where the ECU electrically monitors the EGR valve function. Not sure about '95's. '93's have a "mechanical" or non-electrical EGR valve so it won't be a problem. If you have a '94 and the J-spec engine does not have an EGR valve, then you will need to get a '93 ECU (< $100 used) to prevent the Code 16 Check Engine Light error. IF it is a '94, take the chance to lose the electrical EGR valve which is an unreliable component.
Good Luck
Mac
Old Jan 9, 2002 | 10:53 PM
my car is axually a 94 rx7 but i have a 93 ecu. i purchased the car without a motor (so no ic in it). im putting a apex FMIC so ill need a pettit unlimitted ecu so my car doesn't run incorrect. it shouldnt be any problem with the unlimitted ecu right?
Old Jan 9, 2002 | 11:35 PM
JeffShoots's Avatar
No EGR '95 on for the Rx
Old Jan 9, 2002 | 11:39 PM
JoeD's Avatar
whats the difference between a J-Spec and US Spec engine, other than not having an EGR??
Old Jan 10, 2002 | 01:45 PM
Old Jan 11, 2002 | 01:03 AM
Old Jan 11, 2002 | 03:10 AM
KINETIK_FD3S's Avatar
almost done
Talking
i get my entire 99 front clip on the 20th of this month he he!
Old Jan 11, 2002 | 07:57 AM
wptrx7's Avatar
Newb Photog
damn my car is a 94 and i'm having egr problems (need new one) can i just get rid of it sice i don't have and cats and not aiming for emissions legal?
luigi
aim: wptrx7
turbo-minivan
69
Feb 4, 2016 12:29 AM
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
