Rear alignment ???
Old Jul 5, 2005 | 09:34 AM
azt2's Avatar
Rear alignment ???
I have a 84 GSL-SE, the rear axle looks to be sticking out about a inch more to the pass side than the drivers side. Does any one know how to adjust this problem? I don't think the car has ever been hit....
Thanks
Old Jul 5, 2005 | 09:42 AM
aussiesmg's Avatar
Thunder from downunder
Sounds like your watts linkage has very bad bushings or even a broken mount chack that first, the linkage locates your rear end laterally.
Old Jul 5, 2005 | 02:02 PM
azt2's Avatar
thnaks, I'll check it out
Old Jul 5, 2005 | 08:50 PM
trochoid's Avatar
Old Fart Young at Heart
Funny, mine does the same thing, and I have replaced every wear item underneath the car, except the idler arm. That is a very long list of parts. Still trying to figure out why it sits off center to the passenger side like that, and it is just about an inch.
Old Jul 25, 2010 | 03:30 PM
TalkSick's Avatar
wannabe racer
resurrecting a long dead thread to see if anyone came up with anything
Old Jul 25, 2010 | 05:34 PM
Keith13b's Avatar
Bent watts link or bad watts link bushings- typically from sliding into a curb.......
Old Jul 25, 2010 | 08:49 PM
trochoid's Avatar
Most of my problem was I tightened everything up while the body was still in the air and the suspension was hanging. Jacked the car up, loosened the nuts/bolts and dropped the car. When I re-torqued everything the rear axle was nearly centered.
If you haven't replaced any parts, as above, look for worn/bent parts, including the control arms and their body mounts.
diabolical1
30
Jan 30, 2016 05:50 AM
ncds_fc
Sep 10, 2015 03:52 AM
rx7jocke
Aug 15, 2015 03:36 PM
