Offset range for 17x8/17x9 on FC?
Old Jun 30, 2005 | 10:42 PM
PolePosition's Avatar
Couldn't find the answer I was looking for, but I'm planning to get 17x8's in the front and 17x9's on the rear of my FC and am wondering what range of offsets would acceptable for the front and rear. Take into account that the car will eventually be lowered. Thanks.
Old Jul 1, 2005 | 03:33 AM
RETed's Avatar
Search?
-Ted
Old Jul 1, 2005 | 07:26 AM
Couldn't find what I was looking for. I'm looking for acceptable offset ranges.
Old Jul 1, 2005 | 09:39 AM
raising arizona's Avatar
Send me your BMX parts
I'll help ya, but there is a FC wheel thread and its pretty lengthy.
17 x 8 +38mm -+35mm front
17 x 9 + 38mm- +32mm rear
Now, it also depends what suspension you have or are getting and what tyre size and manufacture. If you can only really run a 225-45 up front max there is now real need for 8's up front....just my .02.
Rear, stay with a 255-40 unless you have 400-500whp. In this case you'll have to make other adjustments and go with 275-40, but IF you plan on 275's the offset must be spot on. +35 - +30mm....
Hope this helps... I had this setup, but I sold the car
17 x 8.5 +40mm w/ 225-45 front
17 x 9.5 +38mm w/ 275-40 rear and opted to use a 3mm spacer cus +38mm is close.
Brad
Old Jul 1, 2005 | 05:18 PM
Pat McGroin's Avatar
Sushi ******!
Brad
How did the car handle with such a staggered setup?
Old Jul 1, 2005 | 05:55 PM
Brad
Thanks for the info Brad!
Old Jul 1, 2005 | 06:12 PM
igottafc's Avatar
RX7less **(
actually i have 17x8 all around with a 25mm off set. for the rears with a 9 inch wide wheel you could probably get away with a 20-30 offset.
Old Jul 1, 2005 | 10:51 PM
RETed's Avatar
I've posted this a bazillion times.
It's even on my website.
-Ted
Old Jul 2, 2005 | 05:49 PM
Anytime
The car handled real good... I'm using it as pass tense now as I had a chance to sell the 91 TII and took the offer.. I go back and forth with it but I needed a change... I bought a 95 MR2 turbo but of course I still love rotaries.
Old Jul 5, 2005 | 02:21 PM
ARD T2's Avatar
I'd say 8" +25 to +35 depending on suspension
9" +25 to +40 depending on tire size.
doritoloco
Sep 17, 2015 03:51 PM
