Who's selling the block off plates for non-seq?
Old Jan 8, 2002 | 06:52 PM
edpaek's Avatar
I'm lazy... I'd like to buy the plates rather then make them... sorry all :o
Old Jan 8, 2002 | 06:55 PM
Bacon's Avatar
IRS 4 Life
theres only one u need...the one to cover the (air bypass valve?) whaever the actoator on the rear 1/2 of y-pipe
takes 5min if u ave a piece of sheet metal
i may have my old one laying arround...
Old Jan 8, 2002 | 08:22 PM
edpaek's Avatar
serious? only one? I've been researching about this and I thought there would be more than 1???
Old Jan 8, 2002 | 09:30 PM
nrolfes1's Avatar
theres a set you can buy at the rx7 store that has aws, acv, double throttle, and one more i think plus 330 ohm resistors for plugging into empty harness sockets. 95 bucks i think.
Old Jan 8, 2002 | 09:37 PM
weaklink's Avatar
Resident Retard
or chuck at rotaryextreme.com
Old Jan 8, 2002 | 09:58 PM
Chadwick's Avatar
Mr Sparkles
Give Spyfish007 a shout, he is the one that makes them. I have the set and the workmanship is top notch. Just do a search for spyfish007 and you will find the tread to contact him
Hope this helps,
Dan
Old Jan 11, 2002 | 01:16 AM
spyfish007's Avatar
Yellow Dragon is no more
That would be me! Order from me or Jason or Chuck ... it doesn't matter.
Just for clarification. The plates that are sold or to help eliminate useless devices. They are a great way to prep the car for non-seq or single turbo because you can begin to remove the rats nest with these plates. To go non-seq you only need to remove the CCV (charge control valve) in the y-pipe. You can either weld the top of it or put a plug in it. I could make this plate, but I would need a GB to make it worth the time.
Snoopy FD
Dec 8, 2015 01:45 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
