skittle update, some good news, some bad news
Old Jun 22, 2005 | 06:12 PM
felixwankel88's Avatar
Well i have this little oil leak, well today when i was driving it to my dads it turned into a big leak, so i would say the bad news is that my engine bay is covered in oil.. but the good news is the parts are ordered.. but the really good news is i got 45 miles on it, i got the stereo installed, i did the kevin lander electric fan relay write up. and i did a compression test today and results follow as
Front rotor- 87-87-87
Rear rotor 90-90-90
cold and hot start are really good...
peacee
Dustin
Old Jun 22, 2005 | 06:24 PM
Wankel7's Avatar
Haven't we ALL heard this
What parts did you order?
Also, use a torque wrench on the front hub bolt...there is a spec for it and I believe it is 95 ft lbs. You can rent it from Autozone if you don't have one.
Was that a hot compression test or cold?
Good to see the numbers are climbing!
James
Old Jun 22, 2005 | 06:28 PM
o ordered a new front main bolt copper gasket and o ring, the compression numbers where like after the car sat for like 1 hr so i would say warm????? that front main bolt is touqued ive allready checked, im pretty shure i dont have that copper gasket, which is i guess prettty important hahahah..
Old Jun 22, 2005 | 07:00 PM
Stanello's Avatar
backslash beanbagrace
Glad to hear that your compression is going up
Old Jun 22, 2005 | 07:05 PM
yea, when i saw the numbers i got really happpppy
Old Jun 22, 2005 | 07:06 PM
ddub's Avatar
i am legendary
I didn't use a torque wrench on my front bolt, loctite + silicone + air impact = perfectly tight bolt
Old Jun 22, 2005 | 08:57 PM
CodyHokieFD's Avatar
JRB
Excellent news from skittle-land. Get that leak problem fixed and hopefully youll be good to go. Cant wait to see it when everything is finished up.
Old Jun 22, 2005 | 09:50 PM
im up to 55 miles on it, i still drove it with the leak, im waiting for parts from slow mazda, so tommarow, universal copper gasket and lots of RVT and she should have over 100 miles easily
Old Jun 22, 2005 | 09:55 PM
Stanello's Avatar
Sweet, gotta change that sig now
Old Jun 22, 2005 | 10:38 PM
adrock3217's Avatar
Boost in..Apex seals out.
The Skittle is god, just like the redline buzzer
Old Jun 22, 2005 | 10:39 PM
Kory_yahi's Avatar
Look ma'! I am spoolin'!
were is my hat?
Old Jun 22, 2005 | 11:41 PM
Wankel7's Avatar
Dosen't torquing more than stock affect the final endplay?
James
Old Jun 23, 2005 | 12:29 AM
staticguitar313's Avatar
R.I.P. Icemark
sweet deal, told you compression would go up ***** going to be fun man, now go paint it, make it hawt!
Old Jun 23, 2005 | 12:33 AM
ddub's Avatar
i am legendary
James
Doesn't matter unless you keep it pounding down over and over and over. I believe Kevin Landers uses impact for the front pulley bolt. I know I've used every time myself, no problems.
Old Jun 23, 2005 | 02:03 AM
RotaryResurrection's Avatar
I recommend either a medium impact on the front bolt for ~1-2 full seconds, or the locking plate that is found on some of the 89+ engines (more so remans than anything). I wouldn't trust a front pulley bolt otherwise. One of the first engines I ever built had the bolt come out shortly after startup because I used the FSM torque setting. Now I use the impact gun torque setting instead, and havent had a failure or leak since.
Use of the impact won't harm your endplay setting.
Old Jun 23, 2005 | 02:53 AM
iceblue's Avatar
Passing life by
Glad to hear the numbers are going up! Hope it treats you well.
Makes we want to recheck now that theres like 200mi on car. 75F 100R on first check
Old Jun 23, 2005 | 03:29 AM
Mx6-Rx7 Addict's Avatar
Brap Brap Brap
The endplay setting would be the main thing i was worried about affecting...
I torqued mine to 95 FT LB's, but i realized i didn't locktite it, so i have to pull it apart again..
Should i take the torque up higher? Or just use the impact? For some reason, i don't feel comfortable not knowing what the torque reading is it.. (probably because im so used to verifying torque readings, i work on helicopters)..
-Justin
Old Jun 23, 2005 | 10:16 AM
BGH's Avatar
BGH
The copper washer was something I forgot on my
first rebuild. I sliconed it to the front bolt, loctite
on the threads and hit it with a impact. End of
problem.
Old Jun 23, 2005 | 11:20 AM
i took it apart today, and no copper gasket, so i used one from a parts engine, just temp till the new mazda parts come inn
cristoDathird
28
May 30, 2019 08:47 PM
cam_7779
Aug 18, 2015 07:48 AM
