Wolf 3D Discuss the Wolf 3D Engine Management System
Wolf 3D damn injectors
Old Jun 21, 2005 | 05:21 PM
nyt's Avatar
nyt
damn injectors
well the time has come.. since the street port likes a bunch more fuel than the stock port motor (damn overlap) I just ordered some 1000cc injectors for my primaries. hopefully this should give me the extra headroom i need. at around 15psi im around 85% duty cycle.. no good =[
*sigh* i hate retuning =]
Old Jun 21, 2005 | 06:38 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
85%? are you tunning for more boost than that?
Old Jun 21, 2005 | 06:50 PM
nyt's Avatar
nyt
85% duty cycle is basically the most you want to run...
but 15 psi is also at about 86 load which i assume is what you thought i meant...
yeah i want to be able to run 17.5psi on the street with this engine and not have maxed out injectors =]
Old Jun 21, 2005 | 09:50 PM
Michael Smith's Avatar
nyt I have some free software to help you rough out a new map.
http://www.angelfire.com/wizard/freqgengui/
I wrote it and it works ok but give it a go.. its at the bottom Rotary pulse recalculator.
Regards
Michael Smith
Old Jun 21, 2005 | 09:52 PM
nyt's Avatar
nyt
Regards
Michael Smith
yeah its no big deal for me to really retune... but im going to probably do staging a little different now that the primaries are double the size =]
Old Jun 22, 2005 | 06:18 AM
My program can sort any simple parameter including injector sizing and staging close enough to get a reasonable map. This make tuning just a little quicker as you already have the characteristics in your current fuel map. I used it to help convert your map to my engine and it worked well. Actually thats why I made it to save doing lenghty calculations that it is easy to make recalculations without large errors.
Michael Smith
Old Jun 22, 2005 | 11:24 AM
nyt's Avatar
nyt
cool ill take a look..
Old Jul 1, 2005 | 09:18 PM
nyt's Avatar
nyt
woot.. so rx7store (go figure) sends me some injectors that they tell me will fit primaries in my FC... i figure its same price, theyre reselling RC.
NOPE.. totally different injectors, not even close.. so i send em back and get 2 1000cc's from rc.
******* things fit perfect and flow so much more than stock. god im glad those are gone. put those bitches in as soon as i got home and started doin a bit of tuning.. car is easily drivable, but still way rich up top (even taking out the 20% fuel that i was supposed to gain, guess it was more =] fresh clean injectors...)
anyway... 1000cc primaries, car idles and runs beautifully in vacuum.. will post some maps later when i get it tuned better.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
connerfd3s
Sep 19, 2015 05:58 PM
