Power FC removing pills with PFC
Old Jan 7, 2002 | 03:26 PM
KZ1's Avatar
KZ1
I am trying to get full boost in 1st gear, so fac I am only pulling maybe 11lbs, will about 12.5 in others. Has anyone played around with the pills for TPC to try and get faster prespooling for 1st and second? I think I haev a lazy TCA but not sure. Are any of you using other than stock pills with your PFC? I heard someone say there were using the size pettit uses for TPC .64 is this possible?
Also, I had intake temps other day of maybe 15C, so I tryied to lower boost the the stock PFC setting for 10#, well it didn't do jack except lower primary boost and give me boost spikes of almost 1 kg/cm2. WHen the secodnary came on it ran at about .92, same thing when I used my higher setting. I tho0ught maybe I surpoased the limit of WG with such cold air? is this possible or is something awry?
Thanks
Old Jan 9, 2002 | 12:07 PM
KZ1's Avatar
KZ1
bump
so is everyone using stock pills?
Old Jan 10, 2002 | 12:29 AM
SPOautos's Avatar
Hey, where did my $$$ go?
I've been using the Home Depot Racing valves for over a year and they work great. No spikes and it controls boost very well. It takes a little playing with to get them just right but once you get the right they work great.
Id install the valves instead of changing the pills. Its the same amount of work but if the pills dont work you'll be starting all over.
Hope it helps,
STEPHEN
Old Jan 10, 2002 | 07:16 AM
I'm using the valves as well. They can be frustrating while setting but it is better than running the car take it apart change the pills run again and so on untill you get it right. With the valves you just turn alittle and go. I have mine set with a little dip at transition, this works out great as I have never had a spike YET.
Old Jan 10, 2002 | 08:39 AM
KZ1's Avatar
KZ1
cool, I think I will try replacing the pills first since i have them, if I can;t get it rioght I will go with some valves. I can;t believe how lousy all these supposed boost controllers are including the PFC. I can't even turn down my boost lower than abut .88
cheers
Old Jan 10, 2002 | 12:05 PM
skotx's Avatar
Registered Abuser
I'd like to do the Home Depot Racing mod eventually (that's hilarious Stephen). Maybe sooner than I think once I get a boost gauge that's worth a damn. To you guys that have done it, do you have to tweak it for the seasons, i.e. when it gets colder, or do you just spend the time upfront getting it right and go?
Old Jan 11, 2002 | 12:17 PM
KZ1's Avatar
KZ1
I woudl think one would rather tweak with PFC
Old Jan 14, 2002 | 12:11 PM
foko's Avatar
is there a good source of info for the home depot mod..specifically how to do it and set it up initially.
tia
fabian
Old Jan 14, 2002 | 06:31 PM
skotx's Avatar
Registered Abuser
Fabian,
This is a good read: http://www.rx7turboturbo.com/robrobi...controller.htm
RE-Mamamia
Sep 11, 2015 02:13 PM
