Question
Old Jan 7, 2002 | 11:26 AM
khiz's Avatar
Question
I started my car last night to let it warm up and was trying to figure out where my oil leak was coming from on my motor. Finally figured it out it was my oil cap it is broken so it leaks out oil when you rev the car. I opened the cap and looked inside and found all this white gunk stuff in side the oil cap. WHAT IS THAT?? It looked kinda foamy and was all around the wall.
Old Jan 7, 2002 | 11:58 AM
jarrod's Avatar
hate to say this but it sounds likr water too me
Old Jan 7, 2002 | 12:02 PM
Felix Wankel's Avatar
Super Newbie
Was the car warm? That **** will get condensation in there if the car isn't up to operating temperature.
Old Jan 7, 2002 | 12:09 PM
Ryde _Or_Die's Avatar
Also, if it is leaking out, condensation can get in easy enough as well. Change the oil & oil cap. See what happens after you drive it for a little while. Maybe it will go away, never know when you have other problems.
Old Jan 7, 2002 | 12:21 PM
Sniper_X's Avatar
Water in the oil.....
Thats what it is.
Sorry man.
Either that or your 13B has rabies.
Either way, youv'e been bit!
You can try flushing the engine, (do it twice) and then refilling it with oil.
Drive for a day or so and recheck.
If it returns, you probably have a busted water jacket somewhere.
Make sure you fix that oil filler cap first.
Old Jan 7, 2002 | 12:53 PM
hIGGI's Avatar
i have same **** there but i don`t consider it like problem as far as my engine don`t fall on me ;o)
Old Jan 7, 2002 | 02:28 PM
Sniper_X's Avatar
wow...
So your not concerned that every part of your engine is going to rust from the inside out?
The whole engine is in jeopardy (every moving part) as long as there is water in the oil.
One day.
BOOM.
Old Jan 7, 2002 | 02:35 PM
hIGGI's Avatar
there is much better chance that i`ll kill myself and engine will alive ;p
Old Jan 7, 2002 | 02:44 PM
Super Newbie
Its NOT water in the oil. Its just some condensation. This is normal if you dont warm the damn car up. You people look at the negative too damn much.
Now if the dipstick has white frothy **** on it, THATS a problem.
Old Jan 7, 2002 | 04:22 PM
khiz's Avatar
Thanks Guys appreciate the help. I checked my dipstick and it is clean, i'm gonna go buy a new oil cap and see what happens. Just another question, my car was having idling problems and as soon as i took the air filter cap off it was idling fine at 1,000rpm...Also when i rev the motor my boost gauge needle jumps up at after 4500rpm but doesn't do it all the time..
Old Jan 7, 2002 | 05:18 PM
Maybe your air filter is dirty, you have a stock setup or an aftermarket one? I dunno bout those turbos
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
