Canadian Forum Canadian users, post event and club info here.
Cosmo re porting?????????
Old Jun 18, 2005 | 11:01 PM
twinturbofc's Avatar
Brother of Yeti!!!!!!
I have recently aquired 2 housings (thanks almost) and i am wondering how to port out the exhaust ports. Has anyone done or heard of how to do this???
Old Jun 18, 2005 | 11:37 PM
RXciting's Avatar
GrapefruitRacing?
Done it dude, first thing you wanna get a hold of is a porting template so you don't screw up the port, i could probably fax you a nice little copy of mine .
Then you'll want either a nice air grinder and carbide bit, or a good electric grinder. i don't think they make bits small enough for dremel.
you have a PM
Old Jun 18, 2005 | 11:49 PM
Nismo Convert86's Avatar
400WHP or bust
they have carbide bits for the dremel, just doesn't work as fast
Old Jun 19, 2005 | 12:47 AM
the exhaust ports on the RE are much smaller than regular ports.
Old Jun 19, 2005 | 01:10 PM
FC3S.USD's Avatar
Where is my Life ?
there designed to give low end torque, as they came from a heavy sedan ( the 13b re and 20b's )
Old Jun 19, 2005 | 03:42 PM
nik's Avatar
nik
Using carbide bits for a dremel to port exhaust will take forever. The bits just clog, the teeth are usually too fine.
I have the RB race exhaust template you can borrow if you like.
Old Jun 19, 2005 | 08:06 PM
IAN's Avatar
IAN
Rotary Reborn!
If we can borrow the porting template for the exhaust that would be great. They have some diffuser installed in the ports. Someone told me an allen key will take them out?
Thanks Nik
Old Jun 19, 2005 | 09:25 PM
R.P.M.'s Avatar
Likes to swear....alot
No an allen key will not work, nor will trying to drill them out.
I read on Nopistons that some engine porters use a small metal screw and tap into the roll pin that holds the sleeve in, then just pry it out....I have tried this before, but it didn't work for me.
Old Jun 19, 2005 | 10:39 PM
I was thinking about that good thing you talked me out of trying lol. How can i get those pins out as i'd like to swap the ports with my old ones???
Old Jun 19, 2005 | 11:57 PM
R.P.M.'s Avatar
Here ya go Jay: https://www.rx7club.com/2nd-gen-archive-72/removing-swapping-rotor-housing-exhaust-sleeves-401058/
Oh and if that doesn't work, I'm sure you and Ian will figure something out
Those engine pull pics still make me laugh!!!
Old Jun 20, 2005 | 12:25 AM
RXciting's Avatar
GrapefruitRacing?
The little screw thing didn't work for me, the screw kept losing it's thread, so i just used a mega screw with much deeper threads, also alot harder.
Old Jun 20, 2005 | 12:42 AM
400WHP or bust
you car drill them out using a concrete drill bit it's much harder then a normal bit so it won't take forever. then slide out the old nes and slinde in the new ones reinstall new ro;; pins andf you should be in the clear.
and nik i said it would take for ever with a dremel, i know first hand.
Old Jun 21, 2005 | 08:02 PM
rx_prez's Avatar
got paint?
I used a screw (broke about 10 doing it) you just have to find a nice hard screw. from there put some vice grips on the screw and hit it upwards. dont bother trying to pull that is useless. Once i foudn the right screw it was acctually really easy. Dont bother trying to drill them... its useless, that metal is rediculously hard.
Old Jun 21, 2005 | 08:32 PM
Thanks man i appreciate the insight.
Old Jun 21, 2005 | 08:37 PM
400WHP or bust
concrete drill bits work, they are harder then the hardened roll pins, just get a high quality drill bit.
Old Jun 22, 2005 | 07:25 AM
Cheers!'s Avatar
Former Rx7 *****
go buy two 13b-rew exhaust diffusers and replace the 13bRE diffusers with the REW one. Done. Btw that steel insert is super hard, it was designed for super high temp environments. You are going to need a rear die grinder and nice bits to be able to port that thing.
Old Jun 22, 2005 | 08:57 AM
RXciting's Avatar
GrapefruitRacing?
I was actually able to just cut them out. I used regular high-speed dremel with a carbide 1/8" shank and bit. Just literally cut the diffusers out.
Old Jun 22, 2005 | 09:15 AM
Aaron Cake's Avatar
Engine, Not Motor
Regular hardware store grinding stones will work just fine on the material.
Old Jun 22, 2005 | 09:30 AM
rx7onfire's Avatar
Too many toys...
I have a bridgeported 13B-RE in my TII, and what we did with the exhaust ports was ditched the Cosmo sleeves and used TII sleeves. We then used a nice RB race port on the housing. Heres some pics:
Old Jun 22, 2005 | 11:48 AM
nik's Avatar
nik
I know you said it. I just wanted to add extra information.
I tried the screw method, busted about 30 screws and my hand doing it. It's crucial to find the right screw... I even tried tapping the pin as suggested in the linked thread. The tap simply broke into the roll pin.
My method:
If you are sourcing your sleeves from scrap housings, then you can simply destroy the aluminum of the housing to expose the pin and slide out the sleeve + pins. Then on your good housing, if you are scrapping the sleeves you can dremel the sleeve in the area of the pin from the inside of the exhaust port, then use a punch to push out the pin.
This method destroys 2 (scrap)housings, 2 (useless)exhaust sleeves. It saves all the roll pins, and it takes about 20 minutes total.
josef 91 vert
14
Sep 17, 2015 09:22 PM
