Whats The highest flowing High flow cat?
Old Jan 7, 2002 | 10:49 AM
Rx-Revin's Avatar
Old Jan 7, 2002 | 10:56 AM
airborne's Avatar
King of the Duct Tape
not sure but my ntech just barely squeaked me pass emissions
Old Jan 7, 2002 | 10:57 AM
twinturboteddy's Avatar
Grumpy Lurker
N-Tech
Old Jan 7, 2002 | 11:05 AM
Rx-Revin's Avatar
Thanks for the reply's How is the Bonez high flow cat and does it reduce the noise of the exhaust.
rx7eaven's Avatar
I got N-tech and I love it! I don't know if it is the highest flowing but supposed to flow 98% better than stock.
Old Jan 7, 2002 | 11:16 AM
Mahjik's Avatar
Mr. Links
The Bonez is fine. As far as reducing the noise of the exhaust, I'm not sure what you mean. Anything that flows better than stock is going to be louder, but it's not as loud as a midpipe.
Old Jan 7, 2002 | 12:05 PM
the_glass_man's Avatar
Will u do me a kindness?
Yeah I heard that its really nice.
I'm allergic to cats, thats why I run with my ASP Exhaust (Midpipe/Catback in One)
Old Jan 7, 2002 | 12:51 PM
Jonesboro's Avatar
Are both the N-Tech and Bonez high flow cats true 3" ID? For some reason I thought I once read that the Bonez high flow cat is 2.5" ID and the N-Tech high flow cat is 3" ID.
Old Jan 7, 2002 | 01:13 PM
airborne's Avatar
i don't know about the size but sound of ntech compared to stock is noticeable louder. not midpipe loud though. i dig it.
has everyone been passing emissions with just ntech? i forget which reading it was but the guy put down one point under the limit, i thought he might of done me a favor
Old Jan 7, 2002 | 02:46 PM
theman's Avatar
I prefer the Random Technology cat. Flows awesome from personal experiences on a few different cars, RX-7s and Supras included. Big 3" ID and seems to run really clean... just a couple decibles quiet compared to a midpipe.
Old Jan 7, 2002 | 03:21 PM
rx7_lover's Avatar
well yeah i have. (Cal. smog)
intake - DP - N-tech cat - CB w/ stock ECU
FYI, i passed pre-test with PFC but decided not to use PFC for the main (real) test.
Old Jan 7, 2002 | 03:23 PM
Which one doesn't require an air pump?
Old Jan 7, 2002 | 07:38 PM
JoeD's Avatar
highest flowing high flow cat is the N-Tech. i heard that it flows 96% as well as a midpipe.
Old Apr 4, 2002 | 01:07 AM
DRAG0NEER's Avatar
question --- If the N-tech hi-flow cat flows 96% as well as a midpipe, then why wouldn't it cause boost creeps as midpipes do??? Thanks in advance.
Old Apr 4, 2002 | 01:31 AM
rynberg's Avatar
None. Any cat will require the air pump.
Old Apr 4, 2002 | 02:42 AM
maxcooper's Avatar
WWFSMD
The N-Tech can be used without the air pump. It comes with the port plugged. If you want to use the air pump, you'll need to have a pipe welded on. If you need to pass inspection, you probably need to keep the air pump.
See pics and read info about the N-Tech cat here:
http://www.maxcooper.com/rx7/parts_info/cat/index.htm
-Max
Old Apr 4, 2002 | 03:02 AM
happyham's Avatar
i just asked this on another similar thread, but would the borla xr1 muffler on a mp be quieter than a high flowing cat? if so, i would definitely ditch my cat for the borla mufflers and have the advantage of a straight through pipe, without fear of being pulled over for noise pollution. (yes, i know if i DID get pulled over, i'd be dead meat for no cat)
Old Apr 4, 2002 | 09:00 AM
ttpowerd's Avatar
HARRRRRRRRR
I got the n tech (thanks glass man) and it flows really well. Pretty loud and great construction. I recommend it
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
