Annoying squeaking in reverse
Old Jan 7, 2002 | 10:47 AM
Jaemie's Avatar
Hi,
My 87 GXL N/A...
I am getting an annoying squeak after letting the clutch out in reverse (does it a little bit when starting off in 1st as well then quits). It is really loud, starts out slow and gets faster as speed goes up. (clutch in and squeak stops). It sounds like it's in rear of car. Could it be the drive-shaft and u-joint? I replaced a broken half-shaft/u-joint with a good condition used one in 98. Or could this be tranny/clutch related? Arghhhh!
Any info would be appreciated!!
Thanks!
Old Jan 7, 2002 | 11:34 AM
Icemark's Avatar
This is only happening while the car is moving right? Not when the clutch is moving in or out?
I might be looking at the brakes first, particularly the rears.
Old Jan 7, 2002 | 11:57 AM
Jaemie's Avatar
Mark,
It only happens after you let the clutch out in reverse....and the car starts rolling backwards...faster you go faster the squeak is. The brakes are relatively new. When you push the clutch back in or put car in neutral it quits. No load...no squeak.
Gotta love it.
manoflego
19
Sep 30, 2015 05:19 AM
1NSIGHT
Drifting
Sep 29, 2015 12:18 PM
Boans
V-8 Powered RX-7's
Sep 25, 2015 04:34 PM
BLK 93
11
Sep 9, 2015 10:56 AM
