tach reading
Old Jan 7, 2002 | 12:35 AM
seein7s's Avatar
tach reading
My friend has a 12a and the car starts up and runs fine while warming up. then you here a click under the dash, then the tach reads 0. the car kills in about 2 minutes or so. he has an after market tach and reads everthing till the end.
Old Jan 7, 2002 | 12:46 AM
WackyRotary's Avatar
standard combustion
the fuse for the fuel pump is burn't out>believe that is it. is't happened to me. Its a 20amp one. IT controls the tack and the fuel pump.
But there are a couple other things its connected to. IF one of those things are malifuctioning it will short out and burn out the fuse. So if I were you, change the fuse and see if it burns out. Then smell under the hood for some melting plastic or something..
Old Jan 7, 2002 | 01:07 AM
seein7s's Avatar
we can turn the car off, and turn it back on, and the car will run with a running tach. then the problem starts all over again.
rgordon1979
40
Mar 15, 2022 12:04 PM
newtgomez
Sep 13, 2015 07:39 PM
