Clutch Pedal Travel
Old Jan 6, 2002 | 10:24 PM
Ovrclck350's Avatar
Clutch Pedal Travel
How far does your clutch pedal come out before it catches? My Camaro has very very little to go before it catches, and my Blazer had to come almost all the way out. Driving the RX7 seems more like my Blazer...it comes almost all the way out before it catches....normal?
Old Jan 6, 2002 | 11:54 PM
vaughnc's Avatar
knowledge junkie
I believe the NAs have a very wide sweet spot, but I'm not sure on the Turbo II's.
I have an aftermarket perf. clutch on my TII that has a very narrow sweet spot and squeeks if I don't engage fast enough.
Old Jan 6, 2002 | 11:57 PM
Felix Wankel's Avatar
Super Newbie
How worn your disc is also has an effect on the release point. The higher up, usually the less clutch disc you have left.
Old Jan 7, 2002 | 12:03 AM
omochi's Avatar
fd-withdrawal
and inturn, it'd slip more right? ... cause my engagement point is pretty high but my clutch isnt slipping.. at all..
Old Jan 7, 2002 | 12:07 AM
Super Newbie
I think theres a way to adjust the pedal travel. Lemme check...
Old Jan 7, 2002 | 12:10 AM
Super Newbie
maybe this will help
Old Jan 7, 2002 | 12:35 AM
Ovrclck350's Avatar
That is sweet....that is so sweet, it's adjustable.
Old Jan 7, 2002 | 12:37 AM
Node's Avatar
is that diagram for FC?
Old Jan 7, 2002 | 12:39 AM
Evil Aviator's Avatar
Rotorhead
Not by much, and that's just the pedal travel, not the clutch engagement/disengagement point.
Old Jan 7, 2002 | 12:52 AM
Super Newbie
Yeah, but it might help. I had one that had a big *** dead spot in the pedal cause it was way out of adjustment.
Old Jan 7, 2002 | 01:10 AM
Ovrclck350's Avatar
So it won't change how far i have to release before it engages? I kinda like the feeling of having it right when you start releasing
Old Jan 7, 2002 | 04:29 AM
isn't it like bleeding brakes? Get some dot 3 break fluid, And pump clutch until it feels how you like it ? Or am I talking about totally different thing ? My clutch will catch right away, not moving clutch pedal much....
The1Sun
Sep 18, 2015 07:13 PM
