Microtech wiring for x4?
Old Jun 13, 2005 | 07:05 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
wiring for x4?
another one of microtech's products i've got without any wirning info...nothing's labeled either.
so of the 6 pin connector (the outs), what does what?
and i guess the 4-prong receptical (which didn't even come with a connector) input, what does what?
i checked the website, and couldn't find any download info.
so if we say top right, top left, bottom right, bottom left, etc....
thanks
Old Jun 13, 2005 | 08:53 PM
10sec rx7's Avatar
if you got a x4 you got a wiring digram,
the 4 pin goes to the ecu check the wiring loom as there will be a short 4 pin plug on the loom,
use the coil wiring to wire the 6 pin plug the same as a LTX8
Old Jun 14, 2005 | 06:20 AM
it didn't come with a wiring diagram.
and there's no connector
Old Jun 14, 2005 | 02:16 PM
this is bad....i emailed microtech asking for instructions or a diagram and whoever emailed back said they didn't have one.
i spose i could just start pluggin' wires in and checking it with a timing light...
Old Jun 14, 2005 | 06:07 PM
10sec rx7's Avatar
something dosent make sence here.
did you purchase a ecu with a x4 on it??
or are you putting a x4 on a old ecu??
i have the wiring stuff at home ill try and scan it tonight
Old Jun 14, 2005 | 06:11 PM
it's on a buddies car.
i got a box with the ecu and the x4 in it..
if i just started plugging wires in with the timig locked, i'm sure i could figure it out...there aren't all that many choices. i'm just not totally sure if i'd risk damaging anything by wiring it up improperly.
i'm absolutely shocked microtech couldn't help me out!! maybe it's possible i accidentally emailed customer service instead of tech support or something like that.
but thanks a lot for your help bro.
Old Jun 14, 2005 | 07:01 PM
here we go--
microtech emailed me back again. they still don't have a wiring diagram, but it doesn't matter anyway, since they said it won't work with the ecu.
Old Jun 14, 2005 | 07:35 PM
10sec rx7's Avatar
do you want to tell me what ecu you have and what it was suppose to be configured for?? a little more info would certinally help your cause... i cant help with problems when i dont know what you have and dont have
Old Jun 14, 2005 | 08:13 PM
yea--i guess i should have started with that.
sorry about that.
it is an lt12s configured for s4/5 rx7. it's on a cosmo motor, but i'd assume that doesn't matter.
i was under the impression that the x4 was an actual ignitor and could be used to replace the factory ignitors. but since i was just told otherwise, i'm having my doubts now.
thanks again for the help.
Old Jun 14, 2005 | 08:45 PM
10sec rx7's Avatar
it wont work as the LT12s will be configured for 3 ouputs, the x4 is setup to run 4 coils, so you will need to get a X3 as such basically the igniters charge off each other and when you take one out of the loop you will be stuck with only 2 working
Old Jun 14, 2005 | 09:50 PM
very interesting.
thanks once again for the help.
Old Jun 14, 2005 | 11:38 PM
now i just found this on the site:
the X4 and X6 Ignition Module Boxes are used in direct fire applications. The X4 has 4 channel output (4 cyl outputs) and X6 has 6 outputs. These are used in conjunction with LT10S and LT12S ECU's . We have chosen to now run external boxes rather than internal igniters as we once did , enabling us to run more advanced hardware on the boards to cope with our new IGBT Ignition boost function which is available on LT10S and LT12S ECU's as a standard feature.
Old Jun 15, 2005 | 02:36 PM
fastcarfreak's Avatar
3rd motors a charm I hope
ok wait. I just ordered through the microtech group buy, a LT12S, the x4 ignition box, and 4 coils. Am I getting the wrong things? What am I suppost to have for my 3rd gen?
Adam
Old Jun 15, 2005 | 03:54 PM
i dunno, but microtech said it won't work--even though they say it will on their website.
does anyone know if you have to get your microtech specifically set up for use with the x4/6 boxes?
Old Jun 17, 2005 | 07:27 AM
black_fc's Avatar
fast car freak
you should be getting a LT10s, x4 and the 4 coils
then everything will work in harmony
Old Jun 17, 2005 | 08:00 AM
Dale got back to me and told me everything is fine for my setup, because i ordered the microtech for the aftermarket coils. I went with the LT12S because I wanted the wideband datalogging capability. Otherwise I would have just ordered the LT8.
Adam
Old Jun 17, 2005 | 08:37 AM
Poweraxel's Avatar
who did your buddy buy the x4 unit from? those guys shouldnt of sold him that unit and they should of gave him some tech support for the wiring diagram
Old Jun 17, 2005 | 10:34 AM
^ straight from microtech. he's a dealer.
if i have a problem with my 10 when it gets in, i'm just gonna scrap the idea and grab a haltech e8. i was migrating over to microtech because i was tired of the problems with the haltechs, but i guess every ems is gonna have its own can of worms.
toplessFC3Sman
Mar 20, 2018 01:54 PM
DocHoliday89
Oct 12, 2015 07:42 PM
FC3S_nataku
Sep 15, 2015 12:36 PM
cosmo7
West RX-7 Forum
Sep 14, 2015 09:47 PM
