Best Ground on the Car???
Old Jan 5, 2002 | 08:08 PM
BiG WaNkLeR's Avatar
Where is the best spot for a ground on the car?
I want to ground my black pressure sensor ground to stop my hesitation
Old Jan 5, 2002 | 09:00 PM
BhamBill's Avatar
That would be the lug where the negative from the battery terminates at the starter.
Old Jan 6, 2002 | 09:11 AM
C. Ludwig's Avatar
www.lms-efi.com
The battery....
Seriously, the starter is good. Or the bolt on the driver's side strut tower where the ground wire from the battery is attached.
Chris
Old Jan 6, 2002 | 12:11 PM
crossbar17's Avatar
wheres the black pressure sensor on a 1988 rx7 SE n/a???
Old Jan 6, 2002 | 03:22 PM
HAILERS's Avatar
HAILERS
If your new ground for the sensor does not work and you also make better grounds at the ECU, you might take a look at the secondary injector plug wires. Both of those on my N/A had been burnt in a fire and new ones had been spliced it to the harness. The spliced wiring was, how shall I put this, not done quite right,(previous owner or course) and caused periodic stumbling when the pedal was put to the floor. If none of that works you might try another pair of secondary injectors. If you have the time, you might see if swapping the primary with the secondary injectors gives a different scenario. If it does maybe it is the secondary injectors. Seems if you did this the stumble would happen at a different rpm etc.
Crossbar, here is a picture http://home.earthlink.net/~burntoast/ well actually here http://home.earthlink.net/~burntoast/images/rx7/maf.jpg Oh by the way. On the turbo the manual calls it a pressure sensor and in the NA section they call it a boost sensor. At least in my manual. Screwed up people.
Monsterbox
Jul 29, 2022 10:48 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
cam_7779
Aug 18, 2015 07:48 AM
