West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
New 87 tII in LA , need help!
Old Jun 6, 2005 | 06:29 AM
Chris Fraley's Avatar
Hey i got this 87 tII not long ago but the ****** wont start and from what the last owner said the block has a coolant leak and last time i tried to turn it over oil started leaking from it. Anyone know of a shop or knowlegeable mechanics in the LA/818 area that i can take it to? I cant spend alot of money but i need help for sure.
I want to work on the car myself but my tools and know how is limited. I learn fast though.
Any referances would be greatly apreciated
Old Jun 6, 2005 | 07:29 AM
Siraniko's Avatar
RX for fun
check out West Forum. There is a thread on LA builders.
Old Jun 6, 2005 | 08:25 PM
fcturbo2's Avatar
hmmm there is TRI POINT ENGINEERING @ Canoga Park. But beware that they will charge you alot. Also try ROTARY SHACK in the same vecinity as Tri Point. Robert will hook you up if you tell him you found out about his on this forum. If the previous owner said coolant leak inside the engine then it will need a complete overhaul. You can go the cheaper way if you want to do it yourself and go with a JAPANESE SPEC engines. Try to stay with the same year 13BT. There is a guy on this forum (JAPAN2LA)Brian, who sells JSpec engines here. And the best part is that he is local. 87- 88 Japanese spec engines will run you less than $1,000.. Good luck and hope that helps..
Old Jun 18, 2005 | 05:51 AM
i cant aforde tri-point, to me thier prices are very unreasonably even if they are the best.. 5500 for a engine rebuild LOL.
ill check out rotary shack and ill talk to brain right now, anyone from rotary shack on this forum?
thanks fcturbo2
Old Jun 18, 2005 | 07:02 PM
Jesuscookies's Avatar
I can haz rotary?
J & G Automotive in La Cresenta.
He is a good rotary mechanic, and will not rake you over the coals.
Ask for Gazo
1 818 957 7530
Old Jun 19, 2005 | 10:56 AM
RX729's Avatar
I LOVE PISTONS
R o t a r y S h a c k
Rotary Shack
Email ; robert@rotaryshack.com Phone: (818) 576-9191 Fax: (818) 576-9125
Location: 9344 OSO Street,Unit J Chatsworth, California, USA 91311
Robert at Rotary Shack did my turbo setup om my RX-2...He's resonable and does a fantastic job...Bring him cheese and he'll hook you up.
Old Jun 20, 2005 | 12:40 PM
RXgirl7's Avatar
IT LIVES!!
mazdatrix in signal hill...ask for john, he can fix anything. come in on a friday, im there all day.
also rotary power, i think they are in gardena(correct me if im wrong, folks)
LA area is ripe with rotary shops!!
Sethix
Nov 3, 2017 11:48 PM
MidnightOwl
Sep 25, 2015 10:24 PM
