help with pill needed
Old Jan 5, 2002 | 01:16 AM
slopoke's Avatar
hi, i was trying to put in a pill i got today to lower my boost but cant figure otu which hose it goes in, the guy described what it wouldb e like and i have pulled out the one i thought it was but there wasnt a stock pill in it, i thought there would be, i am looking at hoses right under the air intake tubes, and right behind the front intake tube that goes down, on the waste gate control i believe, does anyone have any advice they can give me, or pictures would also be great, thanks for your time and help, scott
Old Jan 5, 2002 | 01:45 AM
slopoke's Avatar
Wow I just read my post and it was like hyroglyphics. I was in a hurry since my car is in pieces and i would like to get it working before tomorrow. All i was asking through that sweet spelling and typing job was where the pills are located. I read all others posts I could find and everyone can find theirs but me thanks, scott
Old Jan 5, 2002 | 01:57 AM
slopoke's Avatar
Ok after some more research I and looking at diagrams, I seem to have the right hoses. Their should be factory ones in each hose right? because neither of mine have pills in them, and from what I have read my boost should be 7 not 14. i am confused, please help, scott
Old Jan 5, 2002 | 11:13 AM
dis1's Avatar
www.silverbulletrx7.com
7 is too low, 10 is what you should aim for. The second hose is the secondary turbo precontroll. It's fine if you don't have a pill in that one. I don't and I'm fine. As for which is which I don't remember. Try going to a few web sites. One should have a pic or two. If you are still having problems by later tonight e-mail me.
Old Jan 5, 2002 | 11:26 AM
slopoke's Avatar
i have been to every site i can think of and am pretty sure i have the right hoses. and from what i have read if you take the pills out you will have 7 psi, and there are none in my lines and i have 14 psi, so that is what confuses me, if i put a pill in the lines then it will restrict it more and givve me higher boost, correct? so i am not sure why there are not pills in those lines. thanks for any help, scott
Old Jan 5, 2002 | 01:42 PM
Trexthe3rd's Avatar
Some cars have the air restrictions built into the nipple instead of the pill in the hose. If there is a pill in the hose, you ahould be able to feel it when u squeez along the length of it. It's fairly easy to find, but it is a pain to get out.
In the first case (restriction in the nipple), you'll have to cut the nipple off (using a dremmel or similar) close to the tip (don't cut off too much). put the new pill in a new piece of hose and reinstall.
If there is a stock pill then u'll have to disgard the old hose, and insert the new pill into the new hose and reinstall. Hope this helps.
Old Jan 5, 2002 | 01:57 PM
slopoke's Avatar
yes that does help thank you. i am starting to think that i may have new turbos in my car, since i have a 93 and it should have the pills in the lines. and since i dont maybe they have been replaced with newer ones that had the nipples instead of pills, could this be right, thanks, scott
Old Jan 5, 2002 | 02:07 PM
spooledUP7's Avatar
There and back again
You may have rebuilt, or newer turbos on your 93, but pills or not, you should not be getting 14 PSI unless you have:
1. A remapped computer and you don't know it.
2. An incorrectly adjusted waste gate control rod. (The Shop manual makes mention of the proper adjustment.)
3. A venting waste gate actuator, waste gate soelnoid, or precontorl actuator or solenoid.
4. A leak in the piping "after" the pills.
Any time there is a leak aafter the pills, the actuators will not close the waste gate, or precontrol doors as fast, or as much.
Old Jan 5, 2002 | 07:00 PM
slopoke's Avatar
ok thanks for the info, i will check for leaks, i guess i will jsut keep saving for a profec b and jsut stay off the gas fora while, thanks, scott
David Hayes
13
Sep 5, 2022 12:45 PM
runner83
1st Gen General Discussion
16
Aug 26, 2015 05:16 PM
