Murder The Proxy!
Old Jun 2, 2005 | 11:07 PM
RX(ZONE)'s Avatar
Can't get tires off
Ok my freaking tires wont come off, im trying to change my brake pads, and i cant get the freaking tires off. I cant get it off with the tire iron, and even air tools are not getting them off. Has any body come across this before, and if so what can i do?
I have an 86 GXL no mods..
Old Jun 2, 2005 | 11:14 PM
bigdv519's Avatar
IFO Forced Induction Slo
The lug nuts wont come off or the tire wont come off. I ask since I've experienced both scenarios.
For the lugs: Spray with some penetrating oil. Put the tire iron on a lug, and pop the iron with something like a deadblow hammer.
For the wheels: Hit them with a deadblow from underneth the car, toward to outside of the car. Turn the wheel and repeat.
Old Jun 2, 2005 | 11:18 PM
RX(ZONE)'s Avatar
Lug nuts wont come loose. I tried to use a little bit of penatrating lube, but i ran out, the lug i used it on though still would not come off.
Old Jun 2, 2005 | 11:32 PM
i've had this problem, but on my 240. seriously, the fastest/easiest way to get them off is just to drill out the stud or try to break the stud off some how and just replace them after you get the wheel off.
Old Jun 2, 2005 | 11:35 PM
JSmith0101's Avatar
Play Well
Impact wrench, with tons of torque, does the trick. I just had to do it the other day
Old Jun 2, 2005 | 11:40 PM
RX(ZONE)'s Avatar
Unfortunatley, I dont have one of those.
Old Jun 2, 2005 | 11:48 PM
WonkoTheSane's Avatar
Green Flameless
A local rental store should be able to hook you up for about 10 bucks.. it'll be well worth it to rent it for 3 hours.. just make sure you loosen (Then tighten!) ALL of your lugnuts while you have the impact wrench, so you never have to worry abou this again.
Old Jun 3, 2005 | 12:02 AM
RX(ZONE)'s Avatar
Sounds cheap enough, thanks.
Old Jun 3, 2005 | 12:49 AM
jhammons01's Avatar
Carter 2.0
Are you using that cheap *** lug wrench provided with the car??? You need a four way lug wrench available from any parts store or Walmart.
Old Jun 3, 2005 | 12:50 AM
RX(ZONE)'s Avatar
No im not using that excuse for a tire iron, im using a 4 way.
Old Jun 3, 2005 | 01:05 AM
DC350's Avatar
Rotor Head
Take your car to a tire shop, have them take off the lugs, put "never seize" on the studs and zip em back on shouldn't cost much man.
Old Jun 3, 2005 | 09:47 AM
i took my 240 to a shop, they couldn't get the nuts off, i got an impact wrench, that wouldn't get the damn things off. so, if all this fails, i'm telling you, just drill out or break the studs off and replace them.
Old Jun 3, 2005 | 01:01 PM
IaMtHeRuThLeSs1's Avatar
I'm awesome!
it sounds like whoever took your tires off before you put them back on with an impact wrench... The lugs nuts NEED to be torque'd correctly (80 ft lbs of torque for the FC).
Never let anyone put your lugnuts on w/ an impact wrench, most dumbass' have no clue wtf they're doin w/ those things.
Old Jun 3, 2005 | 01:35 PM
Innovation's Avatar
Get a 3/4 inch wrench with the right size socket and get a 4ft steel pipe and use as a breaker bar. Had to snap two of mine off but it worked.
Old Jun 3, 2005 | 04:11 PM
RX(ZONE)'s Avatar
I made the mistake of letting candian tire inspect how much my brake pads were worn down. They were the closest and i had to time to bring it else where.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
MACH7
May 25, 2005 09:38 PM
