MAF Sensor cleaning?
Old May 30, 2005 | 05:24 PM
jdonnell's Avatar
I tried several times posting but it never came up? I heard K&N air filter oil can collect on the MAF sensor wire causing idle problems, and to clean the wire using carb cleaner. Where is the wire-all I see is a cone?
Old May 30, 2005 | 06:32 PM
HAILERS's Avatar
HAILERS
There is no wire in the air flow meter. There is a carbon track in the interior.....but no wire.
Old May 30, 2005 | 06:51 PM
jdonnell's Avatar
Hmmmm..ok. I heard there was either a 'wire' or 'wire grid', but what I heard was generic on a cartalk show. So I'm guessing then you cant or dont need to clean the 'carbon track' (whatever that is?).
Old May 30, 2005 | 07:00 PM
HAILERS's Avatar
HAILERS
You'd cut the RTV from around the black *D* shaped cover and remove it by prying the edges up with a tiny common screwdriver. There you'll see the carbon track. Radio Shack has a aerosol can of fluid that is for cleaning electrical devices. PCB board's that is.
Old May 30, 2005 | 07:01 PM
cmjaure's Avatar
a.k.a. Mike
alot of newer cars have a "hotwire" maf and that might cause them problems but as for us i wouldent worry about it.
Old May 30, 2005 | 07:02 PM
cmjaure's Avatar
a.k.a. Mike
guess I dont know much about ours then huh. Ill have to do that to mine also.
Old May 30, 2005 | 07:07 PM
jdonnell's Avatar
Ok, thanks. I dont remember a 'D' shape cover so I guess I'll pull it out again maybe next weekend. HAILERS, sounds like you cleaned yours before. You recommend cleaning it or just leave as is?
Old May 31, 2005 | 04:16 AM
HAILERS's Avatar
HAILERS
Leave it alone. The cover is black. It is in the shape of the letter D. It is approx four inches long/wide. Pure black plastic cover with a bead of clear RTV around the edges to seal it and hold it in place. Can't miss it when looking at the afm.
Old May 31, 2005 | 05:30 PM
jdonnell's Avatar
Yeah, I will leave it alone like you recommend. Thanks
Old May 31, 2005 | 08:20 PM
RotaryEvolution's Avatar
Sharp Claws
he is talking about hot wire mass airflow meters, this problem does not apply to our cars, i would suggest disregarding all of this.
oiled filters can wreak havoc on current model cars, i have seen K+N filters tear up transmissions. they even cause problems with diesel engines by coating the intake temp sensor with oil causing them to read improperly and cause drivability problems, in some rare cases engine failures.
Old May 31, 2005 | 10:36 PM
tIIforever's Avatar
terminally boosted
hey did anyone figure out how to use another air flow meter from a different car like a 5.0 mustang
Old May 31, 2005 | 11:58 PM
Syonyk's Avatar
How does a K&N tear up a transmission? They're not adding *that* much power, are they?
For reference, the S4 has a flapper door AFM (door gets pushed open by airflow, the farther the door is open, the more fuel needs to be added). The S5 has a cone type AFM (the faster the airflow, the farther the cone gets pushed back).
-=Russ=-
Old Jun 1, 2005 | 02:01 AM
Sharp Claws
the filter soaks the MAF sensor hot wire and sends a wrong signal to the PCM, both the PCM and the TCM(trans control module) are one in the same and use many of the same signals to calculate shift points.
befarrer
Microtech
Aug 22, 2015 05:52 PM
