exhaust temp.
Old Jan 4, 2002 | 05:51 PM
exhaust temp.
The pipe that is before the cat, and before the smaller pipe comming from the thermal im guessing, is getting red hot, I dont think that is suppose to happen is it?
Old Jan 4, 2002 | 06:15 PM
Barwick's Avatar
SCCA Rookie
I'm not sure, it happens on RX-7 race cars with mostly stock engines, can get red glowing hot on the header. Now if you put the manifold under some pressure (engine flexing too much, accident, or something like that) when it's hot, the header is basically shot, cause it's going to bend REAL easy.
Maybe the cat is clogged? I dunno
Old Jan 4, 2002 | 06:49 PM
Thanks for your reply, I'll most likely spring for the racing beat header next year, along with the rest of those goodies they sell there.
Old Jan 4, 2002 | 09:17 PM
hanman's Avatar
I wouldn't suggest running your car with a cat that gets red hot. You are risking catching your car on fire. Not a good prospect. I would go ahead and replace it now.
just my opinion,
hanman
Old Jan 5, 2002 | 08:09 AM
its not the cat, there is a pipe before the cat and before the smaller pipe that ties into it, that is covered in heat shielding that is getting that hot..
Old Jan 5, 2002 | 11:12 AM
Barwick's Avatar
SCCA Rookie
right, but it might BE that the cat is clogged, causing excess heat buildup (maybe, I dunno)
Old Jan 5, 2002 | 07:15 PM
hanman's Avatar
ANYTHING getting red hot is a major fire hazard. Something is surely wrong, I am guessing that your cat is clogged up. I would fix it and not have that worry. Also, in the mean time don't park over grass, you will ignite it and your car will go up with it.
hanman
Old Jan 5, 2002 | 09:44 PM
allright guess i'll spring for that stuff a lil sooner, im not sure yet, what I am suppose to be getting, a powerpulse muffler, a header, and a presilencer, what else is there that is the usual buy from racing beat??
Old Jan 5, 2002 | 11:24 PM
Winnipeg85GSL's Avatar
Spring for the complete system, I believe you save a few greenbacks by not buying seperately. Get a midpipe with no cats or get your local muffler shop man to weld up a pipe with a new random tech high flow cat or something of the like. Running without a cat can be kinda smelly and/or loud. You'll need to do this since the RB system does not includ it and buying that piece from RB is probably a waste of money because a muffler man can do the same for much cheaper. This is just the midpipe I'm talking about him doing.
Old Jan 6, 2002 | 12:04 AM
hanman's Avatar
I run a RB header, and an RB presilencer into a Monza muffler. I would forget about the cat unless you have emissions laws. If so, forget my advice, I don't have a clue how to pass any emissions tests. This is Kansas, we don't even teach evolutionary theory in schools anymore, much less worry about the environment.
just my opinion, i could be wrong,
hanman
Old Jan 6, 2002 | 10:54 AM
nope, this is indiana, we have fields?.. sounds good thanks
Ian_D
Sep 6, 2015 10:38 PM
doritoloco
Sep 5, 2015 12:41 PM
vmerino
Sep 5, 2015 11:26 AM
