Smog testing!
Old May 29, 2005 | 03:30 PM
younG_Gunner's Avatar
Re-Mama Mia!
Smog testing!
Sorry if this sounds stupid, but can you use OEM N/A parts in a turbo II to pass smog? need to know for test
Old May 29, 2005 | 03:50 PM
RotaryEvolution's Avatar
Sharp Claws
there are very few emissions parts that fit on a T2 from an n/a, what parts are you asking about?
Old May 29, 2005 | 05:33 PM
HAILERS's Avatar
HAILERS
No. The ACV works different in many ways on a turbo vs a non turbo. Turbo used air PRESSURE to open/close the Relief valve in the ACV while the non turbo uses VACUUM. Bottom line is you can't swap acv b/t the two.
The airpumps inlet/outlet are arranged different and the bracket for the airpump is different b/t the two.
The only parts the same are the Switching solenoid, Relief solenoid, Port air solenoid and Split air solenoid. And the Split Air solenoid and Port Air solenoid are irrelevant to emissions testing.
Old May 29, 2005 | 09:11 PM
Re-Mama Mia!
Im not quite sure what's missing, but this is not for my car. My friend said that when he bought his FC, all emmissions were taken out. And now he doesn't know wat he needs to put back. I was only asking about N/A to turbo because our other friend has one as a project right now. From taking a look underneath, I know that his straight pipe isn't going to pass. Can anyone else come up with a possible "check list" That would be much appreciated.
Old May 29, 2005 | 09:17 PM
Sharp Claws
rats nest(under the intake manifold, the steel lines that control vacuum to the emissions comps.)
the solenoid rack under the oil filler neck
the air pump
the Air Control valve on the side of the intake manifold
the air feed line to the main cat with the checkvalve down near the end of the pre cat
the pre cat which bolts to the turbo
the main cat itself
stock airbox
i think thats about all of it as far as emissions is concerned.
Old May 30, 2005 | 01:26 AM
Re-Mama Mia!
Karack - Do you have any of these parts or know of where we can get our hands on them. Thanks for all your help so far!!
Old May 30, 2005 | 01:39 AM
Sharp Claws
i don't have any extras but i'm sure if you ask around the for sale section here i'm sure you will find someone who has them.
edit:
almost forgot this one if yours is an S4:
EGR valve
Mps_hell
Sep 19, 2015 10:02 PM
Erosangel
Sep 18, 2015 04:06 PM
JP's 93 fd
Sep 16, 2015 01:12 PM
